Question about Garden
L opened and cleaned my carburetor nw its idling very high.even if l adjust the idling screw
    Problem Solver:
  • 7 Answers
On a lot of weedeaters there is a holddown nut collar that
secures the weedeater throtlle cable to the motor housing . if you removed the cable from the carbuerator and loosened this collar
you can adjust the idle speed by adjustng the collar back and forth
towards and away from the carbuerator . Simple adjustment to a major headache.
Posted on Nov 21, 2013
  • 85 Answers
SOURCE: Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
Posted on Aug 19, 2009
  • 3640 Answers
SOURCE: Poulan Pro PPB250E trimmer won't idle
clean and repair carb, make sure the mounting gasket is ok. and does not have a vacuum leak.
Posted on Jun 09, 2010
rycgl
  • 1545 Answers
SOURCE: wehave a weedeater featherlite string trimmer, how
Without removing them and slotting the heads on them, a special tool to turn them is available. They have them on E-bay and sell for about $10 and up...but be careful messing with the factory settings as the carb is quite sensitive to change, unless it is so worn that it needs to be rebuilt.
Posted on Jul 04, 2010
  • 144 Answers
SOURCE: How do you adjust the high speed mixture screw? I
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Posted on Feb 28, 2011
  • 640 Answers
SOURCE: Weed Eater PE550...What is the
Soft seat the set screw and back out 1 1/2 turns. This is the standard to start adjustments from. Set the low speed one first, then the high. With it running and warm, couple of minutes, turn in until starts to run rough, then turn out til is starts to run rough, then set in the middle of those two points. Go to the other and repeat procedure.
Posted on Jul 25, 2011
What is the problem if carburetor idles high even when valves (mixture, idle) are at low adjustment?
are you allowing the car to warm up first before checking your adjustment screws? have you also checked the timing of your vehicle?
Jul 28, 2014 | 1990 Toyota Corolla
Carburetor air screw adjustment
Hi Hya
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Apr 26, 2013 | Samsung Galaxy Mini S5570 Android 2.2...
How to adjust carburetor settings
Hi Norberto Mora
Bud
Oct 10, 2012 | Toro 2-Cycle 25.4 cc Straight Shaft Gas...
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
Wt 194 settings
Hi
Sep 09, 2012 | Stihl 026 Ms260 024 Ms240 Original Walbro...
How do I adjust the carburator?
There are two needle screws that can be adjusted to make the engine run properly. Be certain that the carburetor is clean and the diaphragm is in good condition, and the fuel is new. The two needle screws mentioned above should initially be adjusted at one turn open from turned in all the way (lightly seated). Each of these needle screws performs different functions. One is for idle and throttle response (this screw is marked "L" and the other screw is marked "H". L and H are marked on the carburetor body and also on the plastic "shroud" near the adjustment screws. These screws are not interchangeable, being foolproof since the thread sizes are not the same. When properly adjusted the low speed screw (L) allows the engine to idle properly and throttle response will work properly. When the high speed screw is adjusted properly the engine will have correct power at full speed. Adjust the low speed screw so that the engine idles and when you squeeze throttle all the way to wide open the engine should not hesitate and should come up to full speed and when you drop the throttle it should idle nicely without stalling. Now adjust the high speed screw. Hold throttle wide open, holding it there while you adjust the high speed screw. If this scares you (be carefully so that the spinning chain does not cut you!) you may adjust the high speed screw at idle, turning it just slightly in or out. The high speed screw should be adjusted so that the engine does not run clean at wide open throttle but sputters slightly, slightly adjusted open from running clean to slightly sputtering. When under load (cutting a log) the engine should run clean. Good luck!
May 21, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Carburetor is running rich.
Hi jim paton...
You may have some trash/debris in your jets that is causing your engine to run rich, or maybe some did not adjust the high speed/idle adjustment screws properly
Normally you will adjust your idle jet to 1/2 to 3/4 turn open from the bottom seated position.
The high speed jet is adjusted to 1 1/2 to 1 3/4 open from the bottom seated position, after the engine is warm.
Free Answer...Please take time to rate me
Jun 13, 2011 | Garden
The owners manual for my Ryobi 210 describes carburetor adjustment but the photos do not show which screw is the idle mixture adjuster.
The Low speed adjustment screw is the one marked as "L" and would be adjusted during:
1. Idle - to insure running smoothly, and
2. Acceleration - to transition from Idle to High Speed.
The High speed adjustment screw is the one marked as "H" and would be adjusted during:
1. High speed or Wide Open Throttle. Turn about 1/8 either way to gain top RPM's and then back off slightly.
The final screw is an Idle Set screw. This screw sets the actual speed of the Idle and is the screw attached to the end of the throttle cable as it terminates at the carburetor. Turning it:
1. Clockwise - increases RPM's (speeds up motor)
2. Counter Clockwise - reduces RPM's (slows down the motor)
Sep 28, 2010 | Ryobi Garden
Bogs out
First check the air cleaner. Clean or replace it. You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw usually on the left or right side of the carburetor on the outside of the housing. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn. After adjusting the mixture it might be necessary to readjust the idle speed.
Sep 12, 2009 | Garden
Toro lawnmower starts then cuts off. It appears to be leaking fu
If there is a fuel leak causing this problem it could be from the line going to the carburetor or the float bowl. If no leak is present there, could be flooding or a sticking needle in the carburetor allowing fuel to enter constantly.
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
