Question about Technics SH-GE90 Home Equalizer
High pitched noise all channels - Technics SH-GE90 Home Equalizer
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
There is a constant high pitch noise on the left input channel.
Sounds like you may have a defective unit. I would return it for exchange.
Oct 29, 2015 | Behringer (UCA202) Sound Card
Sansui aux-410r amp crackling when switched on followed by high pitched sound and other sound like vinyl played at high volume and stylus being dragged across it .can anyone help please.
This is some kind of componant fault. To find out where determine if the sound is in one channel or both. If in both it could be in the power supply or in something that has both channels common to it. If in just one channel than at least you have the good channel to work with. You can test the bad channel by poking it with an insulated tool. It should make buzzing noises. If it makes buzzing noises in the good channel and is differerent in the bad in anyway you have found something. If the sound also comes and go suspect bad soldering.
Oct 27, 2014 | Audio Players & Recorders
High pitched noise coming from TV
could either be the speakers on the tv packing up and the only best way to fix this either take it into a shop to get repaired or just bin and get another one depends on how much it would cost to fix
May 18, 2012 | Memorex MT2206 TV
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
High pitched noise
The power supply is starting to fail on your LCD. The noise you hear is because the circuit is trying to provide the proper power to the rest of the circuitry and is forcing itself.
The noise does increase if you tune to an HD channel because of more demand for power for a brighter picture.
Let me know if you need further assistance.
Sep 18, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
52 in RCA widescreen HDTV Monitor
high pitched squealing noise >> im thinking is the color wheel which will also give you the yellow color, don't know if that would also cause your screen to blank.
mcm carries RCA
Feb 01, 2008 | RCA HD52W59 HDTV Projection Television
Technics SH-GE90 Home Equalizer Logo
32 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
