Question about Regency 4720 4724 4660c
Regency 4660c keypad ready light always flashing all the time
I have a Genie Directlift 2060 garage opener. My wireless keypad has always worked fine until now. I enter the code and nothing happens. I replaced the battery with the same result. I followed the...
Your wireless keypad may be flashing the red light to falsely assure you that it is working when, in fact, it is not. Another possibility is that the receiver has failed.
Oct 21, 2013 | Sears Craftsman LiftMaster Chamberlain...
Having problems with turn signals as well as hazard light not working properly ,we change turn signal switch as well as fuses. THIS IS 1997 OLDS REGENCY 3.8
there are two different flashers for this they may both be bad turn on flash and listen for the clicking noise if it doesnt and just the light comes on replace also check to make sure all your bulbs are good this can also cause this
Feb 14, 2011 | 1997 Oldsmobile Regency
I have a Liftmaster garage remote keypad that I would like to change the code to. I don't know what model it is, but one code opens one side, and another codes opens the 2nd side
The easiest way to reset the code is to clear the opener memory and reprogram all remotes and keypads. First press and hold the learn button on the back of the motor for 10 sec. Do the same on the other motor. Now you are ready to program. First press and release learn button and then press and hold the remote button that you want to program. The lightbulb on the motor will flash once. For the keypad, press and release learn button. Then press 4 digit code and then press and hold enter until lightbulb flashes one time on motor. Repeat this process for each remote and keypad.
Oct 15, 2009 | liftmaster Chamberlain Garage Door Opener...
How to read engine light codes on a 1988 Oldsmobile Regency without using a OBD Scanner?
An auto repair manual such as haynes or cylmer will show you how to jump the terminals and count the flashes and the code explanation
Sep 11, 2009 | 1988 Oldsmobile Regency
Wireless Kepad Does not always work first time
It sounds like you have a bad keypad. It flashes when it is working not when there is a problem. Call and get warranty service.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Apr 16, 2009 | Ovens
Wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Mar 29, 2009 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Flash takes too long
Its all relative. With most of these compact cameras, to conserve power, the camera does not always keep the flash ready to fire at any given second. Firing the flash uses a lot of juice, so if it was always at the ready, the battery life would be reduced to half or less, which would would cause more problems.
When you press the button the camera then tries to cycle up enough flash power that it thinks it will need to light the scene correctly. This will require less time if its in the day and longer if its dark.
Add more time if the battery life is low.
Once you fire the flash and exhaust all the reserve power from the buffer, the camera will need to recycle itself to garner enough power for another flash, this again adds time.
More expensive cameras have better power management and can cycle up faster.
Dec 16, 2008 | Kodak EasyShare C743 Digital Camera
Motorola RAZR V3 keypad works but won't light up
just take the phone to a mobile center and have them replace the flexcable on the phone.
Jun 26, 2008 | Motorola Mobility RAZR V3
Regency 4720 4724   4660c Logo
37 people viewed this question
Top Regency Home Security Experts
Lawrence Oravetz
Are you a Regency Home Security Expert? Answer questions, earn points and help others
