Question about Samsung WA456DRHDSU
Replaced drain pump making noise
New pump makes noise
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Samsung big wash noise when in use no error message or leaks
Drain Pump
To check the drain pump first see if you hear it when it is agitating if it is it is unlikely to be the drain pump. If you hear it in spin or drain cycle check the filter.Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean the filter. If you hear the pump making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump.
Struts/ Shocks
The struts can cause squeaking noise or vibrations. You will need to remove the back panel , top panel, or lower front panel then run machine to check if the noise is coming from the struts. If it is replace the struts
Motor
If the motor hums, rattles,or squeals replace the motor. This is easy to do. Remove the back panel then run machine to check for noises.
Belt
Check the belt for making noises by removing the rear panel and then running the machine, if it is making any noise replace the belt
Rear Bearing
To check the rear bearing remove the back panel and listen for noises or any water leakage around the bearing. If any noise is heard replace the rear bearing. Check with service manual all bearings are not repairable. The outer drum may get damaged trying to replace this bearing on some models.
Proceed according and fix it. God bless you
Jun 09, 2013 | Washing Machines
Maytag MVAT346AWW
Remove the back lower left access panel. You will find the drain pump there. 95% of these problems that you have described is from the drain pump bearing going out. If possible, run the washer with this panel opened and listen to the pump. If the noise you hear is coming from there replace the pump with the new designed pump. Here is the pump to order. To replace the pump, tilt the washer back and remove the belt, then remove the two hoses from the pump and then the three screws that hold the pump on. If the pump is not the problem, post back to me.
Nov 16, 2012 | Washing Machines
My HE2 front load wouldn't drain & spin and was making noises below. i called Affordable Repair and they said the control panel had to be replaced for $200 + labor. i said the noise is coming from u
Hi.
The noise coming from underneath is symptom of a problem with drain pump or drain line.
The standard procedure consists in accessing the drain filter to check if it is blocked, then testing drain pump. Most of the time the noise is caused by blockage at drain filter. In some case the pump is gone.
The control panel gets replaced only after checking drain filter, testing drain pump and also after testing the water pressure switch that determines when to start or stop the pump.
Bye.
G.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
Terrible noise when draining
Possibly more hair pins in the pump or possible the pump is faulty check that the propellor is not loose if so a new pump is needed.
Apr 06, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Noisey pump
Take the drain pump apart and look for debris, or broken pump impeller. Remove the lower spray arm and filter assembly, check for debris in the sump and check the drain check vavle to make sure it is sealing properly. While in there make sure the food disposer blade are not clogges with debris.
Jan 26, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Bosch WFL 2060 Washer pump issue
If the pump is working then you will not need a new board..
Remove the pump from the m/c, connect live and neutral supply to the pump, it should run.
If it does then your problem could be an internal blockage in the m/c.
Hope this helps
Dec 02, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Roper washer not draining
okay you say coupler was broken, make sure coupler is on properly, and make sure your pump is clear of debri, sounds like you washed something heavy, make sure your pump is also clear
Apr 03, 2008 | Roper RAX7244KQ Top Load Washer
Samsung WA456DRHDSU Logo
14 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
