I always use Reginout to fix corrupt registry properly.
Following are the main benefits of using Reginout:-
- Repair and clean registry errors crashes and freezes in applications and programs.
- Optimize and speed up internet through the internet optimizer feature.
- Clean up the backyard.
- System Cleanup Registry Cleaner
- Internet Optimizer feature Services Optimizer
- Defragmenter Startup Manager
Thanks
SOURCE: laptop booting problem
dear sippy
the problem , maybe causing your memory have a problem with other peripheral or onboard vga, try make your USB 2.0 off by setting bios and when you installing windows XP you can push F5 key rapidly , untill you can find two option, you have to choice first option and try to finished the installation.
i hope your problem can solved
thanks
cropp
SOURCE: Blue screen: Stop: c0000218 {Registry File
Hi.
You would have to have the operating system repaired or completely re-installed.
Please rate me. Thank You.
SOURCE: My wife's laptop fell and now the registry is
The registry is THE program that tells your computer, essentially, how to run--what steps to take to load the various setup aspects etc. that have been compiled for your computer. It is not hardware, it is part of software. If you have a restore function, and you can get to it (maybe through going to safe mode--check your manual for how to get to that). you might be able to get things back, but you may have to wind up reformatting the hard disk, which means you lose everything on the computer. Actually, there are two copies of the registry. In case one gets corrupted, the machine will try to boot the other one, so if your machine is, with several reboot tries, not able to get the registry, then you have a significant software problem.
SOURCE: keeps going to blue screen
you have to repair your operating system, so it will overwrite corrupted files but make sure you dont format your ddrive, you might lose your files.
SOURCE: How to fix a corrupted file so windows will work
Code is a memory address. Use system restore to correct corrupted file from .cab?
