Question about Kitchen Ranges
Emerson Pryne exhaust hood fan
The light switch, a push button, does not turn on the light. How to repair or change the switch? Also the exhaust fan does not work.
SOURCE: Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Posted on Jul 18, 2008
  • 171 Answers
SOURCE: baumatic hood bt82.1 lamps blown..
Hi johnnyi6,
I'm Harvey the Master Plumber.
Your problem is: had a crackling noise then pop..looks like transformer has blown,replaced
but still no lights ..fan o.k...don't appear to be getting any power to transformer via switch?...how do you get push button switch out?...
bypassed light switch and lights o.k with new transformer..any ideas..
Yes, I agree, the switch went bad. It snaps in so you will break it during removal. I recomend you get the replacement switch first so you don't have a wire hanging out while you wait for the new one.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
  • 2692 Answers
SOURCE: range master 50000 exhaust fan stopped working
Extremely likely the fan motor.  get to it then , after removing fan blade,plug it in directly to a 110v  outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
Posted on Jan 08, 2009
  • 14 Answers
SOURCE: Recently moved in and I have a Gaggenau
I have the same probelm. My control board is blown. You can see that easily if you open upm the case on top of unit in tehh cabinet in a smaller metal box. If it is blown like mine it will be very obvious.
Posted on Jan 24, 2010
SOURCE: Broan Allure QS3 push button switches for lights not working
you need a new set of controls,
Posted on Feb 24, 2010
Who carries REPLACEMENT' PARTS for PRYNE stove hood looking for a LIGHT SWITCH
the distributor of the brand of equipment you have
you can try these websites for more infomation
www.ask.com/
www.searchfiles.org/
www.wikipedia.org
www.infolinks.com/
/where is pryne distributor business information
/location of service providers of pryne equipment
/contact repairman for pryne stove hoods
Apr 21, 2015 | Kitchen Ranges
How do i acess emerson pryne range hood to change bulb
Mine has a button under the hood on the rear right side (against the wall) that says, "Push to clean." When I pushed it and another similar one on the left side, the bottom of the hood swung down on hinges at the front. Going around the side and looking behind the section that was hanging down I could see all the innards of the hood, and could access the light bulb.
May 28, 2013 | Kitchen Ranges
Emerson microwave mwg9115sl over heats then turns back on after 20 minutes
Your magnetron is overheating, which can be caused by:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
The first suspects in my book are fan failure, blocked vents, or bad magnetron.
Jan 10, 2013 | Emerson Microwave Ovens
The electronic touch control has fallen inside the hood this is the second time it has happened is there a plastic mounting bracket on the switch that has broken? left side of switch I can see a mounting...
Yep! This is a classic problem with the Therador PHE series hoods. Very weak design and NO help from the factory! Just the plastic housing is $82.00 bucks online. The panel is REALLY hard to access and the control boards, inside, fail regularly. The board alone costs over $200.00 bucks! These will fail to switch on the fan or change fan speeds or turn lights on and off or fan off. All of this randomly and arbitrarily so people tend to push the switch buttons too hard, causing the bracket to fail and entire panel body falling off inside. We have had ours propped up inside with two chop sticks for several years now and to get the fan to switch on or change speeds we fiddle with the chop sticks while repeatedly pushing the buttons and sooner or later it comes on. The lights rarely will come on, however. This unit is made by Bosch and they have all the same problems with NO fix except to replace ENTIRE control panel at a cost of $350.00 retail. This is truely an example of modern, fancy kitchen appliance over-engineered ripoff junk. Looks great but it makes sure that the fool who buys into the Brand name and cool design gets to pay and pay again for their naivete'.
Oct 16, 2009 | Thermador 30", 36", 42", 48", 60" Wall...
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
