Question about Crosley CE35100AA Electric Kitchen Range
Gas oven conservator by crosley displaying E1 & F1
CODE E1& F1 BEEPING DISPLAY
fridgetech
  • 473 Answers
SOURCE: What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Posted on Oct 06, 2007
fridgetech
  • 473 Answers
SOURCE: Crosley Range
Here are the fault codes for Crosley ovens:
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Oct 27, 2007
  • 105 Answers
SOURCE: crosley electric stove about 14yrs old
Both indicate replacing the ERC touch pad/ Clock prices vary depending on where you look
Posted on Feb 11, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: The display on my crosley
Hello, and sorry to read about your problem.
Since you reset the power and still have the problem, it sounds like you have a general main board failure,
I suggest you call a service company
I tried to help you. Please help me and vote/rate my response thanks.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 26, 2010
lachinacool_
SOURCE: I purchased a Crosley lp
HI, I actually have the same kitchen, the clock works just fine, now my problem is I do not know how to use the oven, when I turn in on it won't stay on for more than 2 minutes. please help, Thanksgiving is coming and I would really like to cook a turkey! thank you.
Posted on Nov 10, 2012
We r getting an f1 and e1 showing on our crosley gas range
Hi Anonymous, thank you for allowing me to assist you!
Typically, error code F1 on your Crosley gas range indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your range by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I am fairly confident that an authorized service agent will be able to restore your range to its normal operating condition. Best regards - Z.
Apr 03, 2014 | Kitchen Ranges
After a power outage / low current power problem this evening, my whirlpool range, Model # SF315PEKW0 started beeping annoyingly, and displayed the following code F1 E1. Also, after, the oven would not...
The "F1-E1" fault code signifies an EEPROM checksum failure within the electronic oven control. Disconnect power to the range for longer than 30 seconds. Re-apply power and observe the display for longer than a minute. If the failure remains, disconnect power and replace the electronic oven control board.
Jul 24, 2011 | Ovens
Oven door wont unlock/open
E1 and F1 error code indicates a faulty ERC board. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing. Gain access inside the control panel.Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.Turn the power back on. Wait for an hour to see if the code comes back (usually accompanied by a beeping sound). If code comes back, replace the ERC. If it does not, replace the touch pad.
Thank you !!
Jun 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error on display F1 & E1 Stove will not start
HI. This is a safety flip flop error code, caused by damaged circuitry within the electronic control board. This will require you to have the control replaced asap. This will correct the issue.
Part number (for white control) #3196971
Part Number (for black control) #3196970
Oct 19, 2009 | Ovens
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Kenmore oven/range
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Display
This is an error code, the error E1-F1 indicates that the Electronic Range Control/Clock has been blown. You have to get it replaced.
Sgt 48
Jun 04, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Roper gas range Model# FGS337GQ
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0
F5 - E1 and E2 Door latch problem Check door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of your model # 0-5 that will determine which control it takes. Once you have that # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Nov 04, 2007 | Kitchen Ranges
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Crosley CE35100AA Electric Kitchen Range Logo
54 people viewed this question
Top Crosley Kitchen Ranges Experts
Rob
Rob
Level 1 Expert
Lawrence Oravetz
Are you a Crosley Kitchen Range Expert? Answer questions, earn points and help others
