Question about RTO Alternator/Battery Tester
Suzuki smash 110 - RTO Alternator/Battery Tester
There are times that when I start up my suzuki smash, it blows smoke then suddenly stops blowing smoke when the engine warmed up. what's the problem? how to fix it?
possible wrong viscosity oil in use
oil is too thick when cold and the oil ring/s cannot control the oil
use the recommended oil for the engine
Sep 29, 2016 | Suzuki Cars & Trucks
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Susuki smash 110 w/ power but cannot start
clean the points and check the battery terminals as well as checking the spark plugs and fuel/carburettor and fuel lines.
Jun 12, 2014 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Will a 2004 left fender fit a 2007 suzuki forenza
As there are 3 years between cars there are many cosmetic face lifts done to models to make then more appealing each year so this is something you will have to do a lot of investigation on. Probably best to talk with a smash repairer as they would know from fitting parts from wrecks to repair wrecks.
Dec 31, 2013 | 2004 Suzuki Forenza
How to remove rear bumper on Suzuki SX4 and replace it with another?
rtm (read the manual)
alldata dot com.
and there is no limits to damage, only looking and measuring
as you dismantle works. what will be, will be.
on most cars.
1: remove bumper skins.
2: remove bumper mounts. wires, etc.
bingo.
Jan 30, 2013 | 2007 Suzuki SX4
Which is the best smash repair center in sydney for my suzuki swift car
this is usa forum so you many have long wait.
joint a Australia forum for faster replies.
google that. "Australia suzuki forum"
works great.
Mar 23, 2011 | Suzuki Swift Cars & Trucks
Kenmore 110 60942990 dryer works but takes 3 hours to dry a load.
Venting. When elements or thermostats burn out it is almost always caused by venting restrictions. Vent is plugged with lint, smashed(usually from the dryer being pushed back to far) vent run is too long, or nylon stocking on vent outlet. Also check to see if you can pour water through your lint screen. Sometimes fabric softener builds up on the screen and restricts the air flow. Scrub your lint screen to get this build up off. Good Luck, Appliance Specialists
Dec 16, 2009 | Kenmore 62802 Electric Dryer
Need a windscreen for a 1987 Suzuki
you can try www.junkyarddog.com or your local salvage yard or try a local glass place they usually come right to you
Mar 22, 2009 | 1987 Suzuki Samurai
Glass surface of warming zone/plate smashed.
it is an expensive job so it is worthwhile contacting your household insurer to see if it is covered
Nov 25, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
RTO Alternator/Battery Tester Logo
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
