Question about La Crosse Technology Ws-9080u-it Wireless Temperature Station
We just purchased WeatherstationWS-908ou-IT--is there some way to fix the outside temperature--only part of the nos. show.
How do I get it to display outside temperature?
Usually, batteries have to be installed in the remote unit first, followed by house unit. Allow time for the remote unit to begin sending data to the house unit, then you should see it displayed.
May 15, 2015 | Measuring Tools & Sensors
Iv got vauxhall zafria model 2004 outside temperature symbol is not coming on dashboard is that a big problem should take it straight to gargage
No outside temperature just shows the temperature outside the car the snowflake symbol will not show up until it is cold enough outside it has 2 stages yellow is an initial warning of cold temperatures when it gets to freezing the symbol will turn red.
The outside temp warning is not connected to anything mechanical only the engine temerature gauge is so dont worry it will not affect the running of the car but is just there as a warning of falling temperatures outside.
Feb 13, 2015 | Vauxhall Cars & Trucks
I cannot get the outside temperature to show on the inside monitor
Try the usual fix by removing batteries and reinstalling/replacing batteries starting with the outside unit. Wait for as long as 10 minutes for the ouside temperature to be displayed on the indoor unit. If nothing happens after 10 minutes, the outside unit may have failed.
Oct 20, 2013 | Oregon Scientific Bar806hga Helios Solar...
I have a Nurit 8020 that shows "tampered device" is there any option to fix it rather than have to purchase a new one?
Nurit OSP Loader is the the program we use to remove the TAMPER error. Replacing the internal battery and reloading a fresh NOS (nurit operating system) will remove the error. Check our website at freshpoint.org or call us if you can at (775)358-2922 . It can be fixed, you don't need to replace it. thank you.hope this help : - )
Aug 10, 2011 | VeriFone (M19755014US1) Magnetic Card...
My atomic clock won't show the outside temperature and I can't get it set for regular time, it only shows military time. How do I fix these two problems?
Hi
If you have lost the outside temperature on the clock display then do the following:-
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappears.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
Also check the link bellow:-
http://www.ehow.com/how_4597931_set-atomic-clock.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jan 31, 2011 | Office Equipment & Supplies
My 2 star 1.5 window ac purchased on 27/02/2010 hasdeveloped a problem.The fan is running but it is not getting cool.The toll free nos 18001809999 or 39010909 are not accessible.what should I do ?
Check the air filter and clean as necessary.
Check the evaporator coil (the coil behind the air filter) and check the condensor coil (the coil outside the window) for cleanliness and clean as necessary. Check the fresh air intake damper and make sure that it is closed.
Also check the temperature of the air entering the unit (in front of the filter) and the temperature of the air leaving your unit (blowing into the room). The temperature difference should be approx 20degF. If there is little to no temperature difference, you may have an electrical (loose wire, failed component) or mechanical (locked compressor) problem. If your unit is still under warranty, is it possible to return it to the store it was purchased from?
Mar 30, 2010 | Heating & Cooling
Climate control display for Outside temperature
Had the same problem, replaced the ambient air temp sensor in front of the radiator. Cost is like 10-15 bucks. Don't worry if temp doesn't change right away. Took me about 5 miles and then it worked great.
Sep 13, 2009 | 1999 Oldsmobile Intrigue
Outside temperature thermometer on 2005 Ford Freestar van
my thermometer is blinking -40 degrees how can i fix this
Jan 19, 2009 | 2006 Ford Freestar
Outside Temperature Indication
I have a 2007 ram3500 the sensor I found is mounted to the side of the intercooler. it looks like a short probe with wires. are you sure the sensor is bad? probably not much call for one after market. check with dealer
Jun 30, 2008 | 1996 Mercedes-Benz C-Class
La Crosse Technology Ws-9080u-it Wireless Temperature Station Logo
35 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
Tom Chichester
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
