Question about Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator
Not putting out voltage if you plug in to both outlets one ten then it tries
It puts out about 22 volts at first trigger pull then drops off to nothing in about 2 seconds
When I pull the trigger on the saw, I get nothing, I checked the outlet and another tool works, what could the problem be?
do you have a meter to check voltage? measure if voltage is getting to the switch, leaving the switch, an follow it until you reach a point of no volts
Jul 26, 2017 | Saws
I've already replaced the starter, battery, terminal posts, and alternator. It will start of a jump after charging for about ten minutes but will not start when switching the batteries out. It just do
Could be poor battery connections or bad (corroded) cables. Put a voltmeter on the battery: ideal would be over 12.6 volts, if less than 12.2 volts, recharge battery.
If you have a voltmeter, google "voltage drop test" to see how to check for high resistance to current flow. Check the positive battery cable from battery to the starter. It may help you find a poor connection.
Jan 15, 2015 | Cars & Trucks
How to wire put on a new plug on a extention cord
If this is a dryer your fooling around with 220 volts and you should not use an extension cord (it can cause a voltage drop and burn out the motor in the dryer or worse a fire) If you can't reach the dryer outlet then you should have the outlet moved to reach the dryer.
Apr 12, 2013 | Dryers
AC Power Failure
Providing that you the outlet is putting out proper voltage, check the voltage output of the plug in transformer. Used a voltmeter set to AC and attach the leads under the plug in transformer (where the wire normally go) and plug back into the outlet. The voltmeter should be reading around 9 volts AC. If there is no a low or no reading, you have a bad plug in transformer. It can be replaced with a 9 volt AC 25 volt amp transformer. Battery may also have to be replaced, if it is depleted. If this does not fix the problem, you have a bad panel and it will need to be replaced.
Jul 26, 2012 | GE Security Simon Xt Wireless Control...
1986 will not start with new battery
sounds like a defective starter drive.
Sep 08, 2009 | Cars & Trucks
Won't start
I have the same model chainsaw, and sometimes it's very difficult to start. If you pull the plug and it's wet, with the plug still out pull the starter rope about ten times to clear out the excess gas. Dry the plug and put it back in and try to start it with the choke off. If it fires up, be ready to put the choke on if it starts. I forgot to mention that before starting you should pull in the trigger, push down the button on top of the handle, and hold it down while releasing the trigger. This sets the trigger so that it is on slightly. If it doesn't start, pull in the trigger and give it a few pulls that way. If it doesn't start, pull the plug again and see if it is wet. If it's dry, put the choke on and try to start it. If it still doesn't start, pull the plug, pour a few drops of gas in through the plug hole, replace the plug and try to start it with the choke on. If it still won't start, get a Stihl chainsaw.
Jul 15, 2009 | Garden
Inspiron 1521 adapter vs battery
take an ohm meter you can buy for ten bucks at radio shack put the volt meter on DC volts plug the charger into the battery charger end the black lead goes tothe outside and the red goes inside, set the meter for 12 volts dv and mesure the voltage. read the voltage output on the battery charger transformer see if it's within a half volt if not the charger is bad, if it's ok then use rubbing achol and a q tip to clean the battery connectors on the computer and the battery itself, if you do not get the light then pull the battery out and hold the power button in the on postion and hold the enter key for 1 minute and try again, if the lights do not come back on your battery is dead, if the computer will still boot with the battery then the charger is working if it won't boot up the battery is dead. Got it?
Jun 21, 2009 | Dell Inspiron E1705 Notebook
My lincoln welder/generator Ranger 8 will not idle up when stricking an arc, it will idle up if I plug in a drop light.
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
May 07, 2009 | Lincoln Welding Tools
Our Sharp Microwave Model R-508FS has just recently started doing some odd things. If you key in a time and press start, it may continue to microwave but the timer will not count down. Or, if you...
I believe I've solved the problem. I had tried the hard reset but then last night I thought about it and decided that since this house was built 22 years ago, I wondered if the electrician had used the short cut method on installing the sockets for electrical power. So, I measured the voltage at the adjoining socket while heating water. The voltage before turning on the microwave was 122.7 volts. After the microwave was turned on, it dropped down to 107.6 volts. I located the circuit breaker and shut it off and then pulled out the dual socket. Sure enough, they had used the time saving technique of stripping the wire back about 5/8 inch and then pressed it into the back of the socket. I figured it would be better with the microwave pulling 12 amps to just take the wire and wrap it around the screws on the side of the plug, tighten them down and then put it back in the box. Turned the circuit breaker back on and reset the clock on the microwave and did some more tests. No problems so far and when I measured the voltage drop, it went from 122.7 down to 119.7 running at full power. Don't remember the wire size but it was adequate. The only other thing I may try to eliminate any voltage drop would be to go to the master breaker box and tighten down the screw on the breaker going to that microwave outlet. I had tightened them all down in the whole 200 amp box a long time ago, but it probably wouldn't hurt to go thru the whole box again.
Aug 20, 2008 | Sharp Microwave Ovens
Dewalt DG6000 Heavy Duty 6000 Watt Gas Generator Logo
21 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
Jay Plesset
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
