Question about Konica Minolta BizHub C650 Copier
Getting a c2559 error code when replacing a cyan image unit
4 Suggested Answers
  • 13 Answers
SOURCE: Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Posted on Sep 13, 2009
  • 13 Answers
SOURCE: Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
SOURCE: My konica bizhub c350 copier is printing a double
we provide best service in konica all color machines contact me 9871565085 rajesh negi delhi
Posted on May 11, 2010
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
Cyan TCR Sensor adjustment failure
Replace the image unit code has nothing to do with the chip!!!
Feb 04, 2014 | Konica Minolta Bizhub c203 Copier
I have a KonicaMinolita Magiccolor 3730DN. It's showing a Fatal error code OF54H.
Cyan image unit is having problem getting it toner or the toner for cyan bad also the cyan image unit are either the drum or the toner 3 party if they are GET the right ones MINOLTA>
CYAN=BLUE
Jan 29, 2014 | Minolta magicolor 2200 DeskLaser Printer
Error code 2551 of c220
It is a problem with your cyan image unit, see if you have put it ok other way you should change it your cyan developer is dead. change image unit, cyan
Dec 08, 2013 | Konica Minolta Bizhub-200 Minolta Printer
Trouble c-2551 call service
Cyan Image Unit (Blue) Pull out cyan image unit not the cyan toner, Shake the image unit along the axis of the unit we want developer and toner spread evenly along the entire image unit. Then re-install. Reset code by closing and opening image unit door, not toner door. Worse case replace the image unit you do get bad ones.
Additional questions:
1.Is this a new unit?
2. Is it OEM or third party?
3. Is it new?
4. Did you chip it?
Sep 12, 2013 | Genuine Konica Minolta Konica Minolta...
What is c2559
C2559: Cyan TCR Sensor adjustment failure
Clean the TCR Sensor window on the
underside of the Imaging Unit if dirty
or
Change Imaging Unit
Jan 20, 2013 | Konica Minolta 2 Pack Bizhub C-250 C-250p...
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Cyan Imaging Unit Failure, U28 Error Code
the only thing I can suggest is to check the contacts that the imaging unit goes into, and i can also be the imaging unit itself. If i am not mistaken, you should be able to swap imaging units from another color just to see if the error goes away. But if this does not help, you will need to get it serviced. we have fixed these before, and its not a quick fix.
Apr 21, 2009 | Xerox Phaser 7300DN Laser Printer
Konica Minolta BizHub C650 Copier Logo
146 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
