Question about Moultrie Feeder Activator Remote Control
Remote light blinks will not turn on motor - Moultrie Feeder Activator Remote Control
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
Just got my viper 5701 yesterday and the auto start on alarm worked perfectly. I woke up this morning and the auto start would not turn motor on. locks worked and everything. Took it back to dealer they...
The buzzing noise and lights blinking 5 times is part of the "Find my Vehicle" feature. This usually happens when/if you press the button too long. It takes a little getting use to, but keep practicing pressing the Remote Start button down for only a second or less... you should be releasing the button almost immediately after you hear it make the confirmation tone (meaning the vehicle has received the signal to start). If this doesn't help out, then you may need to go back and talk to your installer about trouble shooting!
Dec 16, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Door will not close with remote.
The code you are seeing with 5 blinks is "RPM sensor or motor overload." We can eliminate the motor overload because the door is trying to close. The RPM sensor is a small printed circuit board just in front of the motor. It's a snap to replace and is available at any good door opener company. They will know exactly what you are talking about if you ask for an RPM sensor board.
Aug 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 2006 cobalt all fuses are good new battery no codes show up when the ignition is turned over lights blink motor doesent turn over there is a light on the dash that has a car with a lock through it
This sounds like the anti-theft system - Are you using the original factory key? Have you tried locking the car with your remote and then unlocking it with the remote (if you have one)?
Mar 06, 2009 | 2006 Chevrolet Cobalt
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
first off, hitting extra button on remote would not do anything. Is door up or down/ where is trolley that attaches to chain, by door or motor. Is is jamned against a bolt. Try a paper clip and jump from white to read terminal. Does it work. Does light bulb blink 10 times. I ignore the diagnostic lights and go by symptons. Give more info.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
I purchased Spike the Ultra dinosaur and when I turn him on I can hit the remote and he will make one move and stop and the two lights highest on his head light up for a few blinks then he is off again....
I have a similar problem. My two year old Spike only works for about 1 second after startup, then shuts down with the two pairs of lights nearest his head blinking a few times. I replaced the batteries (main and remote) with no improvement. Called tech and they said the blinking lights indicated a "motor stall" and that I should shake him to reset a position switch. I did that and now he works for 3-5 seconds then shuts off.
Dec 25, 2008 | Video Game Consoles & Games
Moultrie Feeder Activator Remote Control Logo
57 people viewed this question
Top Moultrie Televison & Video Experts
Are you a Moultrie Televison and Video Expert? Answer questions, earn points and help others
