Question about Mag Innovision LT576s 15" Flat Panel LCD Monitor
Monitor goes off after 2 seconds
And hyou need to manually switch on and off
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
MY MONITOR AOC LM725 GOES ON & OFF REPETEADLY ?
No, all you need to do is reset the monitor to factory settings. I fixed mine that way.
If your monitor goes off every 3 seconds (like mine did) you have to be fast or siwtch it on/off few times between the steps to get it fixed.
- 1st. unlock the OSD if when you press 'menu' you get the message 'OSD Locked'. To do this switch off the monitor, and press 'menu' while you switch it on again.
- 2nd. Switch it on, press 'menu' and quickly 'press '<' (left) twice and 'menu' twice to get it reset.
- 3rd switch it off and on again and if still goes off after 3/4 secs, try to reset it again.
I reset mine and it is working find. Before it went blank after 3 secs.
I just tried this because I did not understand why if it was a hardware problem I could see the screen for 2/3 seconds and if pressed on/off it came back, it made no sense as a hardware problem.
Dec 03, 2009 | AOC LM729 17" LCD Monitor
19'' Suyama monitor
There are problem with internal component of Monitor might be EHT is faulty .Its better call vendor for repair
Nov 18, 2009 | Computers & Internet
I need to unlock my monitor
Here is a link to the manual for your AOC 22" monitor.
When the window opens you will see "pdf downloads" on the right side of the page. Click on your manual and download it.
Hope this helps to unlock it.
http://us.aoc.com/support/manuals_drivers
Nov 13, 2009 | Computers & Internet
My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
Nov 05, 2009 | Acer Computers & Internet
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Delay in Monitor display once the system goes in sleep mode
Instead of sleep mode, tyr hibernate. It is generally faster except the whole computer shuts down. When you power back up, you're exactly where you were. Mine takes about 30 seconds.
Feb 06, 2009 | Gateway Computers & Internet
Mag Innovision LT576s 15" Flat Panel LCD Monitor Logo
18 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Tony
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
