Question about Balance CM2019 19" LCD Monitor
Yellow hue I hooked up my monitor to my new Dell computer and everything (brightnes and color) worked well for the first month. Lately, I have a yellow hue that is very upsetting (not bright and depressing). I am running the new Vista operating system. I have checked the monitor cabel to make sure I didn't have any bent pins. Can you help me?? thanks!
Mine also has yellowing...
Dell 1702FP
Posted on Mar 20, 2008
    Problem Solver:
  • 19 Answers
My name is Todd and I'm with Dell's online outreach group.  Have you tried hooking that monitor up to another system to see whether it's the monitor itself or the system causing the problem?
Is the color distortion always there, or is it only happening at certain times or with certain applications or programs?
Let me know if you're able to try this monitor on another system, or another monitor with this system.  If not, we can try a few different things to test it.
Thank you,
Todd
Customer Advocate
Dell, Inc.
http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Posted on Oct 11, 2007
SOURCE:
How do i fix color problems with monitor
try leaving it on for a while to warm up
Feb 11, 2012 | Dell Computers & Internet
My background on my screen recently developed a purple hue to it, instead of a white. Can this be corrected?
This is likley a problem with the monitor's signal cable. Try moving the cable around steadily and see if the color suddenly goes back to normal or changes to a yellow hue. If this is the case and you are able to remove both ends of the cable then a replacement can easily be purchased from a local computer store or online. (Try www.amazon.com or www.monoprice.com).
Mar 17, 2011 | IBM ThinkVision L170 17" LCD Monitor
I get a pop up with a RED CONTRAST screen every few minutes It sometimes goes away if I push the contrast button on my Dell monitor. but it will usually come right back. I have tried everything to stop...
You can try the monitor on another computer to verify it is the monitor and not the display card at fault.
I'm assuming this is an LCD monitor. If you are sure the monitor is the problem, then your monitor's display driver circuit is probably getting close to failing. When one of the three colors (red, green, blue) becomes intermittent, the screen takes on the hue of the working colors. In your case it sounds like the blue is starting to fail.
A repair technician may be able to replace the circuit.
Jul 22, 2010 | Dell Dimension 4700 PC Desktop
It went this greenish yellow hue
Try resetting the monitor to defaults if possible. If you still have the greenish yellow hue then at that point, try another known working monitor on the computer, if the hue goes away then you know the original monitor is bad, if you still have the greenish yellow hue then you know the video card is bad.
Aug 19, 2009 | Kogi L7CH Monitor
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Monitor gets a blue hue
Hey Tricky Cat!
My first advice would have been the cable...since that did not resolve it it can only be 1 of two other things...the video card (might be intregrated on your motherboard)...or the monitor.
To test plug in another monitor if you have one. If the problem resolves it is the monitor...if not then the video card.
You will have to way your expenses to fix...usually a monitor is cheaper to replace...as well as a video card. If it is integrated the cheapest route is to buy a new video card and turn off the old one in the BIOS.
Good luck my friend.
Seek PC Repair
Feb 09, 2008 | LG L1520B 15" LCD Monitor
Screen color is purple
if you have access to another monitor use if to verify the monitor is the problem and not the video card of the computer.
does the monitor allow you to adjust color and tint(hue) because the tint or hue control changes the overall color from green to purple. or the color control circuit has failed leaving you stuc with a purple screen.
Dec 26, 2007 | Dell E176FP 17" LCD Monitor
Everything has a yellow tinge.
Have you tried giving it a good tap on the side? Hey its worked before. Have you tried hooking it to another machine to verify "yellow." Was it yellow on your friends computer? How old is the monitor? Good Luck, Tim
Feb 07, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Balance CM2019 19" LCD Monitor Logo
347 people viewed this question
Top Balance Computers & Internet Experts
Jaime Hernandez
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
