Question about Dryers
Zanussi zde26110w Play Pause button goes red and wont start if the timer is set above 40 minutes.
rdial54
  • 14 Answers
SOURCE: Zanussi TC7103W
Check the relay switch.
Posted on Sep 03, 2008
AlmostBob
  • 550 Answers
SOURCE: press start button but wont stay on
the switch is fine
the switch in all dryers triggers a relay, that then latches and supplies current to motor and heater, until deactivated by door switch or timer switch
inside the control panel,
trace the wires from the start switch to the first device
c27eaf9.jpgmay be opaque.
ensure that the wires are all connected.
if all are connected replace relay
the local part store will have the relay it is common to most dryers
Cant give exact instructions, no experience with particular model
Posted on Nov 03, 2008
  • 306 Answers
SOURCE: Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
Posted on May 04, 2009
Jahn27
  • 1554 Answers
SOURCE: turn timer to 60 minute
The most common cause of this problem is a blown thermal fuse located on the blower housing. It is wired in series with the drive motor and turns off power to the motor if it is blown. The heating circuit is activated by the motor through a centrifugal switch. No motor running, therefore no heat.
Please indicate the make and exact model number of the dryer for further troubleshooting and repair advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 04, 2010
caroldon
  • 17129 Answers
SOURCE: When dryer is switched on
It seems that the program controller unit is faulty or has hung up . Remove the power and keep aside , check if the controller unit has any power issues.
If the unit does not reset the processor must be checked.check for short on the motor , check if the door switch is working.
Check this link for tips :
http://www.espares.co.uk/advice/tumble-dryers/a/9
Posted on Sep 23, 2011
You tube videos start and stop
The videos need some time to buffer/load.
This is indicated by the pale red line that is usually in front of the play bar which is the darker red bar.
Pause the video for around a minute for the video to buffer.
Then push play button.
You may need to set the detail down to 240p to increase the speed at which it loads.
damnor01
Apr 11, 2011 | HP TouchSmart IQ770 PC Desktop
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Anussi ZWD 1271W stops at beginning of program
Did you fix this problem? We have the same with Zanussi ZWD 1472 W. It takes some water and stops after 2 minutes. We need to shut machine down and fill water manually. It works fine then.
Feb 02, 2010 | Zanussi Washing Machines
Zanussi 1000XC Washing Machine - Pause Light Flashing
The ECU is failed. unplug for 40 minutes to try to reset it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Feb 15, 2009 | Zanussi TC7114W Electric Dryer
T.sonic MP3 Player 610 - iT ISN GOING OFF AFTER A FEW MINUTES OF
You have probably turned on the sleep timer.This function sets a time delay to automatically power OFF regardless of playback status.In the SETTINGS menu, use <<and>> to select “Sleep Timer” then press Z and then press the play/pause button.Then use the + or - keys to highlight disable and then press the play pause button again. Let me know if it worked.
Sai.
Nov 25, 2008 | Transcend T.sonic 610 MP3 Player
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
