Question about Universal Remote Control URC URC-A6 - For Audio/Video, TV, Cable Box,
Looking for a setup code for a Sony Bravia KDL-32EX400 using a Tivo remote control
Remote will not turn TV on. It will turn it off, change channels and volume but just not turn it on.
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
SOURCE: NEED CODE FOR SETTING GE UNIVERSAL REMOTE FOR SONY TV
I HAVE A GE UNIVERSAL REMOTE AND I NEED THE CODE TO PROGRAM A SONY TV
Posted on Jun 15, 2009
  • 21 Answers
SOURCE: Two fans with the same remote code.
There are dip-switches in both the remote and the fan. You need to change the switches on one of your fans.
Posted on Jul 14, 2009
SOURCE: monster remote by tv tech codes
Hit code search ... then the TV button .. then turn it off and on alot of times .. until the tv shuts off .. then hit enter ...
it takes me like 10 trys of doing this to get mind to program ... because i always hit the on/off button atleast once more after the tv shuts off because its such a shock when it does finally turn off...
I have to do this once a month because the kids always drop it and knock the batteries out
Posted on Sep 02, 2009
  • 3 Answers
SOURCE: RCA L40FHD41 Remote key
The only way I could get it to work is use Philips Universal remote SRU4208WM/17. You must use the learning code.
Posted on Sep 05, 2009
Sony Bravia KDL 32EX400 stuck on channel one
It sounds that the main system memory IC has damaged. Before make it sure, just make a hard reset to this set, and check whether it helps you. To make it a hard reset, just unplug the AC cord from AC mains wall socket, and re-plug it back after 30 minutes or so.
If this do not help you, check and replace the main system memory IC.
Aug 22, 2012 | Sony KDL-32EX400 32 in. HD-Ready LCD TV
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
Can not change the channels on my Sony Bravia KDL-46V3000. The remote will turn the TV on and off but will not change the channel.
Is this the original remote or a universal remote? Can you change the channel with the buttons on the right side of the TV?
Can you type in a channel number and go to that channel? (this applies if the channel will not change with the buttons on the TV.) Try to rescan the channels (it could be that the TV has the other channels hidden (or lost the list).
If it is a universal remote, you may not have the correct code (just a close one). Try additional codes for Sony TVs. Also when was the remote built? If it was programmed more than 6 months before the TV was released, then it will not have the correct codes. You would need a newer remote. A substitute remote can be obtained from https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?sessionId=4q4-Cd8shqFs_c5rcVcD_Lw or http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=KDL-V32XBR1&uuid=12842263276080 .
I hope this helps.
Sep 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Remote Codes for new Sony Bravia
you should press 10000, which is the code
Mar 06, 2009 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Jan 19, 2009 | Yamaha YSP-1 System
Sony 37" Flat Panel Bravia--cant change from channel 2?
On the original Sony remote control, try typing in a channel manually. Try pressing the numbers "0-4" or "0-5," and waiting for a moment. If the channel changes, then the TV needs to be autoprogrammed. Using the SOny remote control, go into the MENU (or HOME on some Sony remotes), and look for the initial setup screen. It will walk you through the process. The process is also in the original users manual, available on the www.SONY.com website.
Hope this helps you....
Jan 05, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
0000 worked for my XBR4 using the remote called: Comcast Custom DVR 3 Device found here:http://www.comcast.com/corporate/customers/customer_support/remotes.html
Nov 17, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Universal Remote Control URC URC-A6 - For Audio/Video, TV, Cable Box, Logo
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
