Garden Logo
Rick Meyer Posted on Nov 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tractor just quit moving....won't go forward or reverse??
Engine runs, blades work, engage pin in rear is all the way in.....
Salvagedrover
Level 2:
Sergeant:
  • Expert 417 Answers
  • Posted on Nov 22, 2013
Salvagedrover
Expert
Level 2:
Sergeant:
Answers
417
Questions
Helped
199096
Points
688
If you have a release pin, you have a hydrostatic transmission and if you know about the pin, you knew to check the belt and if you saw it was ok, your trans might be cooked my friend.
  • Rick Meyer
    Rick Meyer Nov 23, 2013
    Thanks Salvagedrover....I had to drop the mower deck out of the way and found the drive belt was off one of the middle pulleys...Trans good, easy fix this time...
5 Related Answers
Anonymous
  • 205 Answers
  • Posted on Mar 21, 2009
SOURCE: Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Anonymous
  • 6 Answers
  • Posted on May 10, 2009
SOURCE: need help installing drive belt on lawn
look at the back and see if there is a lever.
it might solve your problem.
Anonymous
  • 10865 Answers
  • Posted on May 20, 2009
SOURCE: hydrostatic cooling fan belt adjustment
If the belt is loose it may simply be worn out and need to be replaced. Look carefully to be sure that the belt didn't come off one of the pulley wheels as this might give it the appearance of being loose.
The way the belt tightener is engineered, there is no tightening to it, just spring tension. Get back and let me know where it is at. I know I can assist you in gettting to the bottom of this problem.
Anonymous
  • 11 Answers
  • Posted on Jun 24, 2009
SOURCE: Honda HTR3009 riding mower runs great but won't
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Anonymous
  • 1111 Answers
  • Posted on Jul 17, 2009
SOURCE: Cub Cadet engine runs but, also will not go in forward or reverse
you didnt say what model this is, but i assume its hydrostatic because it has a drive shaft. is the hydrostatic unit filled with oil¿ if its ok, check the linkage from the pedal to the rearend (hydrostatic drive) make sure its not broken or loose.. if that l@@ks ok, check both ends of the drive shaft making sure the couplers are not broke and the drive shaft is ok. hope this helps.
2answers
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
JD 110 tractor stalls when put in gear
Sound like a safety switch has gone bad. Either the clutch or seat switch are bad.
Mar 24, 2017 • Garden
Kubota T1570 transmission will not engage in forward or reverse. Starts fine and runs fine, mower blades engage, but no movement. Worked yesterday, not working today. Any ideas? Thank you.
Only problems that come to mind are rather obvious ones. My first guess would be a broken HST belt- the one from the engine to transmission- OR part of that belt assembly (idler pulley, slipped off a pulley, broken tension spring). Another possibility would be the pedal linkage. Maybe a pin fell out of that somewhere and the linkage isn't engaging the transmission.
Lawnmower trans?
Thr hydro is at the rear of the tractor so its hard to believe the oil has come from here up to the front, also they have a multi grade engine oil in them not transmission fluid, are you sure this machine is not in bypass mode ( push mode ) the oil is more likley come from the bottom engine seal, and quite possibly covered the belt making it slip.
Jun 21, 2013 • Garden
1helpful
Model RZT42. When you back up the blades shut and when I go back to forward, the blades will not engage.
Some of the newer riding mowers have a safety system on them that won't let the blades work while you are backing up. If the blades are engaged and you put it in reverse they will stop. You usually have to reset the blades, turn them off then back on, when you put it back in forward.
When backing up the mower blades shut down and won't come back on when I try to go forward again.
on most riding lawn tractors you most first disengage the blades before going into reverse moving the tractor stop, put the tractor in a forward gear then re-engage the blades. if this dose not help please contact me. Thank you
Jul 06, 2011 • Garden
1helpful
1helpful
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 • Mtd Garden
2answers
Suddenly stopped driving...
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
Mar 23, 2009 • Garden
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
