Washing machine shaft is not in the centrer - Washing Machines
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 224 Answers
What is the make and model? the shaft has to be there, or else you don't have a washing machine.
Posted on Nov 20, 2013
GE washer WNSB9080B only allows me to run "Drain and Spin", no other cycle. It wounds like there is still water inside when I move the drum around.
In top loading washing machines, the agitator is responsible for moving the clothes through the water and detergent and is driven by the output shaft of the transmission. The output shaft is normally splined and the center of the plastic agitator will have a matching spline to ensure a tight fit. Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Jul 18, 2016 | GE Washing Machines
Removing stuck shaft from Cabrio Washing Machine
use a bottle jack, brace the basket and use the hydraulic power of the bottle jack (halfords sell them cheap)
Dec 07, 2013 | Whirlpool Washing Machines
Shaft stuck in whirlpool cabrio
Need to hit it a LOT harder. 5-7Lb hammer required.
Dec 07, 2013 | Whirlpool Cabrio Washing Machines
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Fisher and Paykel GW712AU.I replaced the main shaft seal and bearings.Now the shaft with the wash bowl attached slides down through the seal,top bearing, spacer and lower bearing causing the motor to
Hi I just read your post.
It sounds like you have got the shaft upside down.
Large nut for the shaft goes on at bottom bearing & put your seal in last.Make sure you put enough grease on the lip of the seal.
Feb 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Agitator came off the shaft.
should be able to just lift agitator off the shaft check threads on agitator and shaft
Jan 03, 2010 | Washing Machines
Cannot get agitator off shaft Hoover 550M washing machine
Had to cut agitator away leaving metal boss exposed will now use a puller to pull off drive shaft
Dec 22, 2009 | Washing Machines
Washing machin cluch
Remove front panel, remove spring clip holding clutch to motor shaft then pull clutch off shaft or gently pry off if stuck.
Sep 09, 2009 | Washing Machines
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
Lg washing machine wf-t902. clothes tangling up
the machine has a broken wire to motor possibly
check that first
if not
does machine spin
otherwise at the bottom of gearbox under drive pulley there is a pring on main shaft and tah locks gearbox up
if this starts slipping on shaft it will only wash one way
remove and rough up shast refit and grease
Mar 16, 2008 | Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
