Question about Vehicle Parts & Accessories
Astrostart remote start
Model 4204Ustarts when engine is warm starts then shuts off when cold How do I fix?
    Problem Solver:
  • 14 Answers
IT COULD BE BAD WIRE LINK
Posted on Nov 20, 2013
2 Suggested Answers
slick42371
  • 42 Answers
SOURCE: I live in Michigan. I
The remote start has has a status option for it to know when the car has started and for it to keep it running. Most techs do it the lazy way and just set the option to voltage sense. You have to have a tech hook up the tach wire to the remote start and then program it for tach sense.
Posted on Feb 02, 2011
2006 ford f-150 truck has a coolstart remote , doors lock, and unlock with remote but engine does not start
It may be the Security module. The "cold start" routine is necessary to make the engine run cold. When you are already inside the vehicle and turning the ignition switch it is not using the "wireless" feature of the FOB's. The ignition switch is hard wired to the vehicle module and would be sending the signal through a wired connection. For the warm start, the "cold start" sequence is not needed and all this proves is you have spark and fuel. Many engines are running too lean to start without the "cold start" sequence. Another remote possibility is a stuck temperature sensor is keeping the cold start off, but that does not explain the truck starting with a key.
Jan 23, 2017 | Ford F-150 Cars & Trucks
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
Nov 24, 2015 | 2007 Jeep Wrangler Unlimited Rubicon 2...
I have an astro start remote 4204/5204 in a 2004 GMC Sierra, when trying to start the vehicle, its starts then immediately stops then starts to crank over motor but does not start...
I don't have a solution, but I have a variation of this problem... My remote start will start the vehicle (2004 GMC Yukon) then shut it right back off after less than 1 second. But, ONLY when it's cold. Once the truck warms up, the remote start works fine. The "start fail" code says "Engine over revving"... Which is odd, because the engine idles the same cold or warm - around 1100 to 1400 at start, then down to about 800 after just a few seconds. Par for the course for me - no one has ever seen this problem before. I was told by a friend not to install an aftermarket remote start on a GMC Yukon, as they are nothing but trouble, but I didn't listen.
Nov 19, 2013 | Vehicle Parts & Accessories
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Nov 27, 2012 | Cars & Trucks
Astrostart 2100 autostart will not work all the time
It would almost appear that your battery is weak. If the engine doesn't freely turn over the remote start will not work because it recognizes the problem. I would also hope that you plug in your block heater when it's really cold.
Feb 06, 2012 | Chrysler Town and Country Cars & Trucks
I have a Command Start remote starter and the remote is worn out and buttons are terrible where can a person get a replacement remote but I dont know model number as there is no markings on remote it was...
Command Start was an AstroStart brand, you need to find a dealer in order to get a replacement remote. They do not sell via the internet. The following link will assist you in finding a dealer near you.
AstroStart dealer locator
Nov 12, 2010 | AutoCommand Remote Car Starter Add-On
Vehicle will not shut off after key is removed.
try starting it with the key and then try to shut it off with the key...
Jan 10, 2009 | 2003 Chevrolet Tahoe
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
