Question about Denon AVR-3802 Receiver
Denon 3802 Amp issue
Hi, I have just installed a Denon 3802 AMP and I've managed to config the Sky/TV, Tuner and VCR, but I can only get sudio from the DVD. The DVD is connected into the Component video input and the Optical 1 audio input, but I just can't seem to get the video to display. Any ideas?
  • 119 Answers
Check the output res. from the DVD, your Denon may not pass high res 720p, 1080i or 1080p and also check the component assignment in the Denons setup
Posted on Mar 03, 2009
No video from vcr denon 488
Make sure you're connecting the yellow RCA phono connector on the back of the Roku to a composite video input (same yellow connector) on the amp. Then the right input must be selected on the amp.
Jan 19, 2014 | Denon Audio Players & Recorders
Have isolated problem to vhf/uhf connection point. white lines flash in pic. w/a popping sound & if they stay for very long there is a buzzing as in over white or over modulation. problem shows when...
Problem seems with main tuner in this tv as other AV inputs working fine so please replace main tuner (TU2) to solve this issue.
There are two tuners mounted on A board TU1 and TU2, please replace TU2 and part number would be written on tuner itself.
TV is approx 10 years old so I would recommend that do not spend lots of money on it.
Thanks.
Feb 27, 2011 | Sony KP-53HS30 53" Rear Projection...
Hi I just bought 1080 blueray recorder and 6500 samsung tv.hooked up dmi cables to tv to denon amp and blueray to tv .had great picture and sound from denon amp.now can only get sound from tv.not sure...
Check your Denon amplifier with other input such as, input from ipod sound to amplifier or any source that provides sound to your amplifier. If you have a built in tuner in your amplifier, Does the sound comes out? If it does then check your dvd setting, e.g 5.1 channel surrounding etc. If there is no sound from amplifier, check your amp with qualified service tech.
Jan 17, 2011 | Samsung Televison & Video
Just connected sky via hdmi through denon 3310 and no sound is coming through the tv. Also do i need to have amp on to view sky via hdmi?
ensure that HDMI is selected in your sky settings.
you would not need an amp at all just to view sky, only if you were routing sound to say a surround system.
Are you only getting no sound from the tv? or are you getting sound via the amp but not from the tv?
Nov 22, 2009 | Denon AVR-3805 Receiver
If i just have a conventional cable, analog and no cable box, how do I get the channels in this sony TV. it only a monitor. what are my options??
Hi my name is Roety,
I can help you with your issue ,
You can use a DVD/VCR or VCR that has a tuner to connect to cable.
Or get a cable box
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 09, 2009 | Televison & Video
Denon avr 3802 amp with the front led power light flashing fast this seems to be the protector circuit is activated how do i solve this?
According to the manual The amp is not ventilated or the speaker terminals have short circuited. Have you been able to resolve this as I have the same problem?
Aug 20, 2008 | Denon Audio Players & Recorders
Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Denon AVR-3802 Receiver
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Set up
You don't need to fake it with a VCR - on the back left side near the bottom there is a Monitor section with an RCA connection and an S-Video connection. Connect one of these to an input connection on your tv and switch your tv to show that input. Select the AMP setting of your remote and press Setup.
Mar 01, 2008 | Denon AVR-3802 Receiver
Denon 3802
m8 think thers hardware problem with it.or it could simply b that wen you pushin the amp hard then some other buttons are gettin pressed at the same time on the bord. couldnt say for sure without taking a look you could send it to these guys an they should do it pritty quick and cheap. http://www.mobilephoneservicecentre.co.uk/
Jul 03, 2007 | Denon AVR-3802 Receiver
Denon AVR-3802 Receiver Logo
265 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
