Question about SMC TigerSwitch SMC6724L2
6724l2 factory default - SMC TigerSwitch SMC6724L2
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Settings
RESTORING
FACTORY SETTINGS
initialization
Mar 26, 2015 | HP Office Jet 4500 G510n
How to reset to factory default
Restore the factory-set defaults
CAUTION:Restoring the factory-set defaults returns all of the product and network settings to the
factory defaults. The procedure then automatically restarts the product.
1.
On the product control panel, press (X451 Series) or touch (X551 Series) the Setup
button.
2.Scroll to and press or touch the Tools menu button.
3.Scroll to and press or touch the Restore Factory Defaults button, and then touch the OK button.
The product automatically restarts
Jul 22, 2014 | HP Officejet Pro X451dn Printer
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
How do I do a reset
This printer doesn't support a COLD RESET
However it will set customer accessible menu settings back to factory default settings
Restoring the factory-set defaults returns all of the settings to the factory defaults.
To restore the factory-set defaults
1. Use the (Left arrow) or the (Right arrow) button to select Service, and then press
(Select).
2. Use the (Left arrow) or the (Right arrow) button to select Restore defaults, and then
press (Select).
The device automatically restarts.
Feb 09, 2011 | HP LaserJet 2605dn Printer
I am trying to change color laserjet 2600n back to English and need some assistance. can you help?
1 (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
Use the
(SELECT).
2 (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then
Use the
press (SELECT).
Then you need to change the default settings back to what they were.
Oct 19, 2010 | HP Color LaserJet 2600n Printer
I am looking for the Security Key
Unfortunatly there is no way of accessing the router security key if you have forgotten it however you can reset your router to factory default here is how
" The Reset button is located on the right side of the product label. There are two ways to reset the Router to its factory defaults. Either press and hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen in the Router's browser-based utility The Reset button is located on the rightside of the product label. There are two ways toreset the Router to its factory defaults. Either pressand hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen inthe Router's browser-based utility" was this helpful?
Oct 05, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Default factory password
Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
  • Username = admin
  • Password = password
    • For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password. Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
This applies to:
  • Most of the NETGEAR devices such as routers and smart switches.
Aug 13, 2010 | Cell Phones
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
SMC TigerSwitch SMC6724L2 Logo
69 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
