Question about Sony XM-1002HX Car Audio Amplifier
Wiring diagram koiiler xm-8686 - Sony XM-1002HX Car Audio Amplifier
I have a Koiiler XM-6666 2 channel amp. I was wondering what size fuse i use from the battery source to the amp its self.
You need to match what is on the amp. If the amp has a single fuse, or multiple fuses rated at a total to 80, then you need to use an 80 amp fuse at the battery.
Apr 22, 2011 | Koiiler XM-6666C Car Audio Amplifier
I DON"T KNOW WERE WHAT
the outputs are normall speaker posts, or 1/4 in jacks. the inputs are smaller and are RCA type inputs, usually red and white or red and black. the speakers may be marked L and R for left and right
Mar 19, 2011 | Koiiler 8686-C Car Audio Amplifier
Hi... When I adjust my radios balance to full right or full left, it gives far stronger bass then it would if the balance were dead center.... When it is centered, there is very little bass......and music...
speakers are "out of phase", meaning that one side is wired correctly and the other side is not. the easiest way to fix this is to just switch the wires on one side, by "switching" the wires i mean the positive and negative wires on the speakers/box? hope this helps, dave
Oct 11, 2010 | Koiiler XM-8787C Car Audio Amplifier
Need wire diagram koiiler xm 7676
U CAN GET ALL UR WIRE DIAGRAMS FROM PIONEER WEBSITE JUST OUT IN UR MODEL NUMBER THEN TYPE IN WIRE DIAGRAM
Feb 13, 2010 | Koiiler XM-7676W Car Audio Amplifier
Koiiler XM8787 Amp power problem
Sometimes i goes into protection when the amp is overloading with power.. Or the amp is touching metal.. Or the ground wire aint in the right place..Or check your RCA's, Speaker wires? if their earthing your amp..
Jan 13, 2010 | Koiiler XM-8787C Car Audio Amplifier
Blows fuses koiiler amp mx-8686
check your ground thoroughly make sure it is making good metal on metal contact and that there are not breaks or cracks in the outer coating. Most times amps throw fuses for that reason.
Mar 09, 2009 | Car Audio & Video
Xm-6650 led light on short is on and no sound
Disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 16, 2007 | Koiiler XM-6650 Car Audio Amplifier
Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
May 11, 2007 | Koiiler XM-7676W Car Audio Amplifier
Car Audio & Video Logo
220 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
