Question about Dell XPS M1530 Laptop
No display problem, vga's out to external, then after 2nd reboot, internal display works, but with errors
Laptop vga's out fine...no display on laptop screen on 1st & 2nd boot attempt. 3rd attempt, display appears, but colors are grey & purple during boot up, then displays ok, but screen brightness ajdustment does'nt work right. its brightest around the middle of ajdustment, but weaker on either side. I replaced screen so far.
    New Friend:
  • 4 Answers
If you have already replaced the screen...
Common problem when replacing equipment on laptops is that the "cable" goes into a flat housing that requires you to lift a little white "gate" then insert the cable and put the "gate" back down. Problems usually occur when snapping the "gate" back down. Pull the cable back out and be sure to lift the gate insert the cable and then put the "gate" back down. Once done give it a light tug and it should hold very firm and not move at all
Posted on Nov 20, 2013
Testimonial: "This solution sounds interesting, where is the white gait ? Is it on the board, etc...If this is the cause, are you saying the cable is having an issue ? Thanks."
  • 2 more comments
  • Ray Mayes Nov 20, 2013
    ...And are you saying this problem is in addition to the 1st issue, replaced broken screen ?
  • Ray Mayes Nov 22, 2013
    Hello Brian, there is no white gait in this Dell laptop, and since you have not replied to my last question, I'll assume you feel that you are not qualified to offer a further solution, rather leave it to more qualified experts, I understand. Thanks for the effort, although it really does nothing to resolve my issue !
    I still need help here, Thanks !
3 Suggested Answers
harvester3
  • 181 Answers
SOURCE: IPC laptop has blank screen
Hi, Boot to windows, using whatever screen you can (external or lcd, whatever is presently working) Right click anywhere on the screen and go to properties (far right tab) you should see icons of two screens, and below that a button labeled "identify". Click on that button and see which screen is assigned number 1 and number 2. You can configure the display properties here, assigning primary and secondary screens, or sharing your desktop with each. Good luck
Posted on Oct 02, 2007
Nowuser
  • 56 Answers
SOURCE: Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Posted on Jan 03, 2008
My screen keep going white
To me this is a hardware problem.
Let's diagnose, and see Shunka_Reid.
Connect a VGA monitor to the laptop.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
http://support.gateway.com/s/notebook/2009/gateway/nv/NV78/NV78lv.shtml
Number 3 - External VGA display port
General example of VGA connector (port), and VGA cable,
http://en.wikipedia.org/wiki/VGA_Connector
Scroll down a little for the VGA cable example.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
General example of a CRT type of monitor,
http://www.wisegeek.org/what-is-a-crt-monitor.htm
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By factory default settings, the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor.
3) External VGA monitor ONLY.
Press, and hold the Fn key down, and at the SAME time tap once on the F4 key.
The F4 key is the Display Toggle-Over key.
Still no?
Hold the Fn key down again, and tap on the F4 key once more.
Do you get a good display on the external VGA monitor?
Post back in a Comment.
Also, has the laptop ever been cleaned on the Inside, to your knowledge?
Regards,
joecoolvette
Mar 04, 2013 | Gateway NV7923u 173Inch Laptop (NightSky...
Compaq laptop prasario cq60 won't turn on yes it's plugged in yes outlet works yes I checked all electrical connections and outlets
have you tried to remove the battery and wait a couple of minutes then re-insert. make sure your battery charger is working, light flashes also indicates low power.
Mar 01, 2013 | Computers & Internet
My laptop is vga,so i have bought a vga cable,and a converter box with HDMI cable. My samsung series 5 tv will not pick up the laptop. i have tried all the options available but it just says check devices...
Wouldn't it be NICE to know what laptop you are referring to
Oh well...........maybe one day
By factory default settings the display should automatically show in the external VGA monitor. (TV. Whatever)
HOWEVER;
Your laptop has at least 3 display options;
Press, and hold the Fn key down, and at the same time tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Dunno. Laptop manufacturer and model number wasn't stated.
(One of the F keys at the top.
Generally;
Acer = F5
HP = F4
Lenovo/IBM = F10
Dell = F8, unless it's Alienware - F6)
Did that? That's how it worked on your friend's TV?
Then your TV is the problem.
Settings I assume. NOT a TV tech.
Regards,
joecoolvette
Feb 07, 2013 | Computers & Internet
Screen will not load just white lines
Does external display work fine? If you have not checked, connect an external display like desktop monitor or a LED TV which has VGA connector to your laptop's vga port. You may have to use some fn keys combination to switch from laptop display to external. If external display works fine then check the display cable connecting laptop motherboard to laptop display. And also check laptop LCD/LED screen. You may have to try another with another screen in such scenario.
Sep 17, 2012 | Pavilion g7-1219wm Notebook PC
When I turn on my HP Pavilion 1x1000 It stays on ,but there is no image on the screen, and stays on please help.
A) Post THE Product Number on the bottom of the laptop. It's in the white Service Tag. P/N = Product Number.
B) On the left/bottom side of the LCD screen frame (Display Bezel), there is a switch. Looks like a small button.
This is the Internal Display Switch. (May not be in this exact position for your model. Look around on the Display Bezel, that surrounds the LCD screen)
When the laptop is closed, the switch turns off the display, (Image on screen), with the computer still on.
Tap it a couple of times lightly, with the eraser on the end of a number 2 pencil.
See if anything happens. That switch may be bad.
C) Laptop off, monitor off, connect a VGA monitor to the VGA port on the laptop.
Example of a VGA cable, and VGA connector, (Port),
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
C) Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
IF not;
There are at least 3 display options,
2) Internal monitor AND external VGA monitor
Press, and hold down on the Fn key. At the same time tap once on the Display Toggle-Over key.
Don't know what exact HP laptop you have. For most HP's it is the F2 key, or the F4 key, that is the Display Toggle-Over key.
(Key has an empty rectangle on it, with a vertical line on each side)
Still no display on the external VGA monitor?
Hold the Fn key down again. (Bottom left of Keyboard)
Tap once more on the Display Toggle-Over key
NO display on the external VGA monitor, means you have a bad graphics chipset.
(By using an external VGA monitor, you are bypassing the Internal Display Switch, and the Display Assembly. (Internal monitor of laptop)
If you have a display on the external VGA monitor, you have a problem with;
1) Video Cable, (Display Panel Cable for HP)
or
2) Display Assembly
Post back with your results, and if you have a display on the external VGA monitor, we will go on.
If you do not have a display on the external VGA monitor, you are looking at motherboard replacement.
Regards,
joecoolvette
May 13, 2012 | HP Computers & Internet
Th problem is lcd
No display on laptop's internal monitor, and there is no blinking cursor?
Start with seeing if it is a display problem.
Connect a VGA monitor to the laptop. If the display does not show on the external VGA monitor, the problem is the graphics chipset.
You did not state the model number of the Fujitsu laptop, therefore all I can give is generic basic information.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
This is an example of a VGA Cable, and a VGA connector,
The VGA connector (Port) on your laptop is either on the side, or back of the laptop. May be marked on laptop as RGB.
You can use a CRT type of VGA monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
If not there are at least 3 display options;
Press the Fn key down, and at the same time tap once on the Display Toggle-Over key.
The Display Toggle-Over key is one of the F keys at the top of your keyboard. F1 through F12.
It will have a monitor symbol on it.
(For example most HP laptops use the F4 key )
No display on external VGA monitor? Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
If no display shows on the external VGA monitor you have a bad graphics chipset. Motherboard replacement.
If a display does show on the external VGA monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
Post back with the results, after using an external VGA monitor, in a Comment.
Regards,
joecoolvette
Apr 25, 2012 | Fujitsu Siemens Computers & Internet
Screen blank with white dot
Problem with;
1) Video cable:
A) Video cable connection on motherboard side is loose, and/or on back of LCD screen.
B) Video cable is damaged.
2) screen Inverter:
screen Inverter is bad.
3) LCD screen:
LCD screen is bad.
4) Graphics chipset:
Graphics chipset is bad.
Suggest you connect a VGA monitor to the VGA port (Connector) on your laptop.
See if the problem is the graphics chipset, Or video cable, Or display assembly.
You didn't state what manufacturer and Model Number of laptop this is.
All I can do is state generic information.
This is an example of a VGA Cable, and VGA connector,
The VGA connector will be on the side, or back of your laptop.
For the VGA monitor you can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
Laptop OFF, monitor OFF, connect the external VGA monitor to the laptop.
Turn the laptop on.
IF not;
There are at least 3 display options.
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
Press, and hold down on the Fn key, and at the same time tap once on the Display Toggle-Over key.
(For an example HP's usually use the F4 key for a Display Toggle-Over key)
Display shows the same on the external VGA monitor?
You have a bad graphics chipset.
[ Some laptops have been erroneously stated as having a graphics card, when in fact they do not.
The GPU (Graphics Processing Unit) is soldered directly to the motherboard.
This is Integrated Graphics.
http://en.wikipedia.org/wiki/GPU
There is no changeable, replaceable graphics card. Therefore the solution is motherboard replacement ]
IF, the display is good on the external monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
After diagnosing with an external VGA monitor, post back in a Comment.
Also post the manufacturer name, and model number of the laptop.
Regards,
joecoolvette
Apr 22, 2012 | Computers & Internet
I am trying to connect my philips brilliance 170p monitor to my dell laptop.....the monitor keeps saying 'no video input'....help?
After plugging it in, you'll need to actually tell your laptop to use the 2nd display and select an appropriate resolution. Go to display settings, select 2nd display, and select "extend display to this display".
Aug 04, 2011 | Computers & Internet
Set up TV as monitor for laptop with Fedora
Try pressing the function key and the monitor key (Fn+ F key). This will cycle through the display modes (Internal monitor, external display, or both). Your monitor key will look like one of the following: 5eab006.jpg009092c.jpg41a2ff0.jpgUsually after you reboot the default setting should be to run the internal display only. Your monitor could possible have gone out, possible the LCD panel or the backlight.
Jan 09, 2010 | HP Pavilion dv6000z Notebook
Dell XPS M1530 Laptop Logo
85 people viewed this question
Alun Cox
