Question about Kitchen Ranges
Westinghouse Early kooka - Kitchen Ranges
We have a Westinghouse Continental Electric Range KHB30XKI that was installed in the early 1960's. My mother loves it. Tiny kitchen, slide out burners, space saving. Please help me find elements for...
Do the elements look like the pictures here?
http://www.repairclinic.com/PartDetail/Bake-Element/5300210961/2548 bake element
http://www.repairclinic.com/PartDetail/Bake-Element/5300210911/2183 bake elemenet
http://www.repairclinic.com/PartDetail/Heating-Element/5300210972/1070 bake element
http://www.repairclinic.com/PartDetail/Heating-Element/5300210922/609530 broil element
I hope it is one of the these the first 3 are different bake elements the last one is a broil element that the only pull out elements westinghouse used and i appears all are still available from there on repair clinic
I hope i have helped you to find the element you need,
Gene
Aug 15, 2011 | Ovens
Instruction for a westinghouse photo electric switch 28kc
See image of Westinghouse photoelectric switch:
http://cgi.ebay.com/Westinghouse-Photoelectric-Switch-257484-/160513724667
If this is not the product you are asking about, then add a comment with exact description of your switch.
See manuals for Westinghouse 28499, T28449 and T28011
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-week
If manuals match your product, add a comment and say which manual, and I will copy the manual contents and post on this thread.
Dec 14, 2010 | Heavy Duty Westinghouse 3-Outlet Outdoor ...
Westinghouse sb915 - draining too early.
1. Is your drain point higher than the bottom of the dishwasher? (ie, does it drain into the garbage disposer or does the drain line drop down below the floor into house plumbing?) Did you just install the unit? You may have to install an "air gap" to prevent syphoning.
2. Did the dishwasher work then suddenly stop working? (asking for clarification)
Dec 13, 2009 | Westinghouse Dishwashers
After power surge...tv will not turn on
that will affect the power supply, check for any open fuse at the early stage of the input current, other than that you need to replace the power supply board by a new one
Mar 31, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Nov 10, 2008 | Ovens
I have a sewing machine from Westinghouse Electric & MTG. It has a pending patent, on one of the plates says 1903-1013 but this particular is pending. The style # is 281650, can you tell me a little...
more examples of desirable and collectible early patented sewing machines, and to get more information on antique sewing machines, please visit our sister website www.patented-antiques.com, where we conduct most of our Internet sewing machine sales from.
Mar 17, 2008 | Vacuums
Model LTV-27w2 westinghouse
The tv got a heat sensor, the only way to fix tv , if you are a tv tech, is to buy a bottle of "freez it" spray small sections of tv in side. It will be clearly where the fault is if you spray correct part that give trouble. Replace that part and Tv will be Ok.
Nov 04, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Kitchen Ranges Logo
206 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
