Question about Hotpoint Washing Machines
Hotpoint hv7l130 very loud banging noise - Hotpoint Washing Machines
  • 68 Answers
SOURCE: loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Posted on Apr 26, 2009
rylee_smith
  • 8619 Answers
SOURCE: loud banging noises
Hi!
The reason of this noise is from loose lower front weight mounting bolts or a loose bolt securing the driven pulley. Check the motor adjustment bolt for tightness. The noise could be from a loose wire harness, plastic purse-lock wire harness retainer on upper hose hitting the top cover or a plastic injection mold standoff on the outer tub bearing housing may possibly be interfering with the driven pulley. Also, check the drive belt for a weak spot on the belt. Ussually felt on the backside of the belt as a "flat" spot. Check the belt for a weak seam and replace it.
It may also occur due to the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 06, 2009
barkencoa
  • 3463 Answers
SOURCE: drum will not move
Try to remove drum belt, and then turn drum by hand, if it does not turn , then you have either siezed drum bearigs, or some thing jammed between the inner and outer drum
If drum turns freely, then check motor to see if it is free to turn.
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
bostonguy08
  • 32 Answers
SOURCE: hi,i have a hotpoint aquarius wf340.which makes a
I had the same issue with a similar machine. Need to replace the spindle assembly (or otherwise make sure) that the belt is tight. Try replacing belt first.
Make sure machine is level. test it by putting some stuffed sockes in the machine, let them get thrown around. Listen for the banging noise, apart from the soft socks hitting the tumbler.
Posted on Aug 08, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Thankyou.
Posted on Jan 31, 2010
Testimonial: "Thanks for your help. In the end it was the front balance weight that had been gradually coming looser and looser and needed fixing pack into place."
Hotpoint ffp187b loud noise from appliance
Where is the noise coming from? The front, back, top, or bottom? Is it a bump, thump, bang, clang, or rattle? Does the sound happen at regular intervals or randomly? It could be the compressor bushings going bad, causing the compressor to bang around.
Mar 25, 2013 | Hotpoint Refrigerators
Hotpoint 1100 banging very loud when spinning,can thi be repaired please?
the chances are its the bairings in the drum that have gone,can you move the drum towards and away from the door easily? if so its prob the bairns,just like on a bike wheel they make the drum spin free but if they break it wobbles out of true causing problems and loud noise
Mar 19, 2013 | Hotpoint Washing Machines
Hi,i have a hotpoint aquarius wf340.which makes a very loud banging noise every time it spins,it works fine otherwise!
Aug 08, 2009 | Hotpoint Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Apr 26, 2009 | Washing Machines
HDA3400G020WW noise
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
Mar 10, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Loud banging nois when compessor shuts down
The banging noise usually occurs when the internal mounting springs are weak. You cannot get to them, they are internal. This causes a banging noise when the fridge comes on or switches off. It can also happen when the starter relay on the compressor makes a bad connection and therefore the compressor does not get immediate good power causing a stutter.
Mar 01, 2009 | Refrigerators
Loud Banging Noise
if its a loud banging noise when the unit kicks off then broken spring in compressor will have to replace compressor check your 2-5th year warrenty in your owners manuel
May 14, 2008 | Hotpoint HTS18GBR
Washing Machines Logo
54 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
