Question about LG Studioworks 563N 15" CRT Monitor
Monitor turn on &off intermittently - LG Studioworks 563N 15" CRT Monitor
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
There is a loose contact in power supply. 1 check for plug or socket loose 2 switch intermittent 3 fuse loose. 4 any connector loose. 5 any component in oscillator looseor print break. 6 swiching transistor print loose. 7 main filter capacitor loose or dry. hope this will help.
Posted on Oct 08, 2007
SOURCE:
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Crackling noises in ADAM A8X
I just repaired an Adam A8X which had intermittent noise coming from the woofer. Turns out it has two (cheap?) volume knobs inside for factory calibration, which are not accessible to the user. In my case the low-frequency pot had collected dust and caused intermittent noise and reduced woofer output. I opened the unit up, rotated the knobs back and forth a little bit and set them back to their original position. This resolved it. Maybe your issue is related. They may have fixed this in MK2?
Aug 31, 2012 | Adam Audio Audio A8X Powered Monitor
The monitor screen shows the content of my laptop screen for the first 10 seconds and after, the monitor turns black
hi check your inverter board, the intermittent power is caused by a faulty component in the inverter.
Oct 27, 2010 | Samsung SyncMaster 920NW Monitor
Why is my computer monitor making (intermittent) ticking sounds?
I belienve it is not an LCD
In that case it is a crt that uses hi voltage cathode and all you are hearing is it's slow discharge like lightening hittin the earth but not in such force
Jul 31, 2009 | Computers & Internet
Monitor screen goes blank
Check the chord of your monitor connected AC Supply.
Mar 16, 2009 | Toshiba Tekbright 15" CRT Monitor
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
Crt monitor problem
If it's intermittent it could be the red drive on the control board, but if it's constant it's probably the red gun failed. I would try the monitor on a diffrent system just to be sure but it's probably time for a new monitor.
Dec 10, 2008 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Sounds like this one needs component-level troubleshooting in the power supply section.
Dec 31, 2006 | LaCie Electron III 22" CRT Monitor
EV 700
my gateway monitor makes a sqreeching noises when you turn it on. after that it starts making that noise like it does when its fixing to come on then it starts smelling like its burning then we turn it off. please help
Oct 18, 2006 | Gateway EV 700 17" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
107 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
