Question about Acer Aspire Timeline X 5830tg Laptop, Intel Core I7, 2.7ghz,6gb,500gb 15.6" Blue
Acer aspire timelimex 5830t wont turn on
Charging light come on but when the power button is pressed it lights up for a second and then goes out and i have to press the reset button to get the charge light back on
  • 50 Answers
SOURCE: wont power up
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
27
Posted on Jul 25, 2009
jennifer720
  • 830 Answers
SOURCE: Acer Aspire One will not turn on
You mentioned a bios system program? Was she trying to flash the bios? If so, then the system (motherboard) may have been damaged. This can occur if there was a power outage or power disturbance during flashing. I would try and re-flash the bios once more and see if that helps. You can get the bios program from the OEM's website and download to a floppy or CDrom. Reboot the computer and see if it will start from disk and lead you to re-flashing. If this doesn't help, you will need to purchase a new motherboard. Check eBay for a resonable priced replacement.
Posted on Sep 13, 2009
hakimmadina_
  • 155 Answers
SOURCE: My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
Posted on Nov 27, 2009
  • 37 Answers
SOURCE: My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Posted on Dec 09, 2009
puertobori
  • 7733 Answers
SOURCE: Acer Aspire One 521 does not boot. When holding
To start the system recovery:
  1. Restart the netbook.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. In order to recover the system using Acer Recovery Media, an external optical disc drive is required.
  2. When the Acer logo appears on the screen, press the F2 key repeatedly.
  3. Press the Left Arrow key until you've selected Boot.
  4. Ensure that the external optical drive is plugged into a USB port.
  5. Refer to on screen instructions to set the first device to USB CDROM.
  6. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  7. Close the CD-ROM tray.
  8. Press the F10 key and then the Enter key to save the changes and restart the netbook.
  9. The computer will boot from the Acer Recovery Media
  10. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD. Note: If there are multiple Recovery CDs, please insert the first Recovery CD.
  11. After the system recovery program has loaded, follow the prompts to reinstall the Operating System.
Note: If you do not have a set of Acer Recovery Media you may purchase recovery media online. If your computer is unable to run the Acer Recovery process, or errors occur during recovery please contact Acer Support.
Posted on Dec 12, 2010
Acer Travelmate 6592G Wont Startup
do the HARD reset. Disconnect the power adapter +battery. Hold the power button by 30 seconds. And then reinstall the power adapter and battery again and test again. this will solve the problem God bless you
Apr 04, 2013 | Acer TravelMate 6592G-602G25Mn Notebook
Acer x3400 wont start up
Remove the Power Cord and then press and hold the power button for 30 seconds. After 30 seconds plug the power cord back in and press the power button. If it reboots you had a Static Charge Buildup and released it by holding the power button for 30 seconds.
When you press the power button do you hear the fan running, disk drives running, cd drive clicks once, anything on the lcd screen? If not I would think your Power Supply is bad and needs to be replaced.
It's either the Power Supply or Motherboard.
Mar 23, 2012 | Acer Aspire X3400 PC Desktop
My acer aspire one wont turn on. the screan doesnt got switched on. pls help?
Does the power light comes on? Try a power drain. Disconnect the adapter, remove the battery, press and hold down the power button for 10 seconds. Put the battery back and the adapter and try to turn it on. Still no display? Take it to an Acer repair center.
Dec 21, 2010 | Acer Aspire One PC Notebook
My acer aspire 5315 wont turn on I press button and it lights up as if gonna come on but screen stays blank and then it powers out its only 1 year old help
Maybe the screen has some problems, or try clicking to the power button for some minutes, or Try charging the laptop, or try to change the laptop's battery.
This is all I know, wish it works :)
Jul 16, 2010 | Acer Aspire 5315 Notebook
Won't turn on. On button glows green and harddrive light flashes and goes out. On button continues to glow. If I hold the on button down 5 seconds it goes out. It was working fine, I turned it off and...
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
^^ this is a copy paste from my own solutions
May 13, 2010 | Acer Aspire One AOA150-1570 Notebook PC
My aspire will not turn on I mash power button and it lights for a few seconds and goes off what could be the problem?
this seem like the battery is not charge.(dead). The power supply is probably not working therefore it is not charging the battery. Check it the power supply has a light.. see if it on. you may need a voltage tester to test the power supply of it dc voltage of 19V Dc,
Jan 21, 2010 | Acer Aspire One PC Notebook
Dec 08, 2009 | Acer Aspire 5315 Notebook
Turn on for one second then turns off
Hi There,
It could be a faulty charger. Try getting another one and try. Failing that it could be a faulty battery. Hope this helps...
Nov 17, 2009 | Acer Aspire 3680 Laptop
I press the power button on acer 5735 notebook the fan kicks in etc , then after a few seconds the power light goes back off before the computer boots up , what could e the cause ?
More than likely a virus or a video card. Hopefully the video card because if it is a virus then you will have to replace the hard drive. Hope this helps
Oct 21, 2009 | Acer Aspire 5735 Notebook
Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Aug 16, 2009 | Acer Aspire 5520-5908 Notebook
Acer Aspire Timeline X 5830tg Laptop, Intel Core I7, 2.7ghz,6gb,500gb 15.6" Blue Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
