Question about Zanussi TC7102W Electric Dryer
Beko dcu8230 thermistor faulty
The dryer is not heating up, only blowing cold air
  • 1122 Answers
SOURCE: no heat
there is a main dryer fuse and a heater box fuse,the heater box fuse is the small bimetal fuse on the heater box,replace that and you should be ok,let me know how it goes-mike
Posted on Oct 12, 2008
SOURCE: Dryer does not heat up
my dryer work but it does not give heat ( kennmore 70 series)
model# 10062712101
ser: 1216293
i am trying to get the manual for my dryer from kennmore
Posted on Oct 26, 2008
  • 67 Answers
SOURCE: Dryer will not blow hot air
first, check the entire exhaust pipe, most of the time the problem is there. every inch must be free of lint. to take apart most dryers: 2 screws hold on the bottom front panel. those screws are near the floor on the front. once that panel is off, you should see 2 more screws, this allows you to remove the main front panel (the one that holds the door) with that off, there should be 4 screws holding the front drum support on. with that off, you should be able to carefully remove the drum after removing the belt from the motor. to get the belt off, you have to reach in from the bottom and push the tensioner and slip the belt off the motor.
good luck!
Posted on Oct 28, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
kachbibi1
  • 979 Answers
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
Beko DCU8230 not heating up
Could be heating element failure
Feb 13, 2017 | Dryers
My former electric dryer started blowing cold air only. I bought a brand new whirlpool and within 2 days, it started only blowing cold air also! I can't believe this is a coincidence. Could...
Hi theresacorle..
It sounds to me like you could have a blocked vent causing your dryer to overheat...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Jun 25, 2011 | Dryers
I have maytag bravos and doesnt blow hot air just cold . i checked went its ok . i think thats heat sensor ? located inside black plastic with one one terminal plog in ? im looking for replacment
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Sep 18, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer is not drying clothes blowing out cold air
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Aug 10, 2010 | Whirlpool Dryers
My whirlpool gold electric dryer model # GEX9868J ,stopped drying it just blows cold air , can you please tell me what the problem is .
Aug 09, 2010 | Whirlpool GEX9868J Electric Dryer
Dryer is only blowing cold air
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Please rate me, Thank you
May 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer goes on. doesn't dry
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
Good Luck,
Hope this helps
Nov 28, 2009 | Kenmore 62602 Electric Dryer
Blows cold air everything works except the air is cold
Good Luck,
Hope this helps
Oct 26, 2009 | KitchenAid Dryers
My creda tunble dryer model 37324 is working but
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 | Dryers
Zanussi TC7102W Electric Dryer Logo
64 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
