Question about Espressione Retro 1385 Espresso Machine
Searching for spareparts for the Ariete Esmeralda 1315
I need an expansionvalve Does somebody know where i can get that ?
I have A ARIETE MODEL 305, What's the easest way to change the head seal
there is either a screw in the middle which needs to come out first then porta filter screen and then pop seal out.
or just to get in there with a small flat screwdriver and gently pry it loose if it doesnt have a screw holding it.
Jan 09, 2013 | Ariete Cafe Retro Espresso Machine
I have a 1991 chevy s-10 blazer 4.3 engine. The fuel injectors are not spraying out any gas at all. I have already replaced the TP Sensor, Fuel Filter Regulator, and the Fuel Injectors still Im not getting...
need to see if the fuel pump is working and has electricity going to it if its and fuel is reaching to the injectors but they still do not spray gas then you need to change the ECM unit thats the computer.
Aug 31, 2011 | 1991 Chevrolet S-10
Semi cold a/c
if everything works such as compressor, fans blowing, lines are cold to your evaporator the next thing would stop the flow to evaporator is 45 bucks expansionvalve stuck or clog not allowing the cold charged feon to flow completely into your evaporator. if you can get to your evaporator and fell the unit ( it also look like small radiator) using your hand and feel the cooling fins to see if it cold. If it not, then it stop at expansionvalve. Expansionvalve work like a valve/gate it open up and close.
Sep 05, 2009 | 1999 Dodge Ram 2500 4WD
Manual Lello 1375
We received this solution from one of our users.
"This espresso machine is also made by Sunbeam and called Café Crema™ EM4800C.
Here is the link for the manual
http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1129
You are welcome"
Dec 30, 2008 | Lello Ariete 45900
Pinter hp 1315
Sometimes it's better to just buy a new printer. They are a lot cheaper these days. If you aren't sure what parts aren't working, it would be a waste of money to buy parts. And if you are sure what parts are not working, check eBay for them. As for the new cartridge, are you removing the protective tape that covers the bottom of the cartridge?
Aug 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Installing hp 1315 all in one printer to window vista pc
You can download your printer driver from HP HERE.
Just select the correct operating system to download your driver.
Jun 16, 2008 | HP PSC 1315 All-in-One Printer...
Espressione Retro 1385 Espresso Machine Logo
29 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
