Question about Gestetner 2212 Digital Imaging System Copier
Error sc 542 - Gestetner 2212 Digital Imaging System Copier
3 Suggested Answers
20YrsCompExp
  • 227 Answers
SOURCE: sc 542-00 trouble code
SC542 is a fuser error code and can ONLY BE RESET by a tech. Type pressing clr mode (button) then 107 then press and hold CLR Stop until a menu pops up. turn offf main power then on again. If there is no serious problem the code will not come back. IF it does call a trained tech. DO NOT CHANGE ANY SETTING in the menu that comes up after pressing in the code. YOU COULD RENDER YOUR COPIER INOPERABLE!!!!!!
Posted on Mar 27, 2009
  • 1297 Answers
SOURCE: Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Posted on Sep 26, 2009
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Sharp photocopy machine showing error code Sc 542
SC 542 Basically the machine is telling you that the fuser did not reach its target temperature in a specified amount of time. In normal circumstances this code will appear if the thermistor is not maintained or replace periodically or in abnormal circumstance the heat lamp blew. This is a Service Tech reset code. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won't come ready until the prior error condition is cleared. basically you will have to care a service tech to clear it
Aug 03, 2015 | Sharp Office Equipment & Supplies
Error sc 542
this is a fusing error
change the set of thermisters in the fusing unit
Jan 20, 2014 | Ricoh Aficio CL3500N Laser Printer
:Ricoh Aficio SP 3510SF error SC 542
Yes your MFP has had a fuser reload error. It's not permanent though. Sometimes the thermistors don't read the right temperature due to the thermistor getting excess toner built up on it or it gets moved away from the hot roller. This SC error usually can be reset by powering down the printer. It must be powered down correctly or you can corrupt the hard drive.
Hold the power button down on the operation panel until the screen goes dark. Then, physically turn the power switch off on the side of the unit. Once the unit has completely powered down and all lights are off, toggle the power switch back on. The unit should power back up normally. If the SC 542 returns, you'll have to have a technician check the fuser out.
Oct 24, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
16 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
