Question about Freezers
I have a Defy fridge/freezer C250 which is not working, i am not sure if it Gas, the bottom was getting cold, then i got someone to come look at the fridge, he then cut a wire at the back of the fridg
It is has a bottom freezer/top fridge, fridge is a new condition, just now working, am at my wits end, as a new fridge is to costly.
  • 3 Answers
SOURCE: Fridge/Freezer combo - Freezer working fine but fridge is not
There is a duct between the freezer and refrigerator. Sometimes this duct blocks off with ice and won't allow airflow. Open your refrigerator door and check for air flow if there is none the duct needs to be defrosted. turn off freezer/ refrigerator and defrost.
Posted on Feb 27, 2009
SOURCE: My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Posted on Jul 28, 2009
SOURCE: Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Posted on Sep 04, 2009
SOURCE: DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Posted on Sep 11, 2009
Freezer works fine but sides get really warm
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
May be overworking itself to stay cold
Sep 05, 2014 | Kenmore Freezers
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
My Kelvinator N245C fridge freezer is ok but fridge not cooling when i open the freezer door , the cold air through to fridge air outlet ok but when the freezer door shut and than no air to the fridge the...
first look for an air vent in the bottom of the fridge(a small grill on the inside wall) & make sure nothing is blocking it, like bread eg: if there isn't then unplug your fridge & let it defrost, check the drain outlet in the back of the freezer, sometimes a small item like a frozen pea gets into the drain & the water freezes around it causing the air not to return to the freezer from the fridge, to push air into the fridge you must be able to get air out or it presurises,
Nov 01, 2011 | Kelvinator 12 cu. ft. / 340 liter Chest...
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
Sep 11, 2009 | Freezers
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Side by side refrigerator is not cold. Bottom freezer is.
if the freezer is cold and the fridge is not then it can be several things. The freezer could have a bunrt out defrost heater, defrost timer faulty, fan not working in the freezer??. all of these things will stop your fridge getting cold, but your freezer will still be around minus 9 deg c. you wont get any air into the fridge as the coil in the freezer is prob all iced over. Dont worry about the heat on the door frame as it is only the anti sweat heater
May 01, 2009 | Maytag Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
