Question about Electrolux 30" Electric Hybrid Induction/Radiant Cooktop - Stainless-Steel/Black
When i turn the power on I get an F blinking
I don't know how to turn it on. It's a rental house and there isn't any manuals
Why won't oven door unlock?
call the retail estate agent and have it fixed
It is not your position to fix rental property equipment
Dec 25, 2015 | Amana AER5844VAW 4.8 cu.ft. 30" Self Clean...
My induction cooktop isn't working. When I push any of the touch pads, the numbers flash. There is no E for displayed, only the various numbers I push.
Call the co. And let them guide you thru this. Does your instruction manual give you any help. Hopefully, your board hasn't gone bad.
Jan 18, 2013 | Thermador Cooktops
I don't know how to connect to the wall plug
I think that I would get an electrician if it isn't a straight forward plug
Jun 10, 2011 | Neff T1323 Electric Cooktop
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
Electical problem?
You really shouldn't have tried this. If you mixed up the neutral and hot wire YOU COULD HAVE BEEN KILLED!!!! You also could have burned out the fan motor. The fan operates on 120 volts the rest on 220. On most cooktops the frame is grounded to the neutral. If you connected this wrong the entire outside of the cooktop could be live. You might not be shocked if you have on rubber shoes but if you touched the stove barefooted you could be killed! The house wire should have 2 hot wires usuallly black or red. It really doesn't matter which is which. There should be a neutral (usually white or bare) There can also be a seperate ground wire (usually green or bare) If only 3 wires from house connect the white and green together. The minimum wire size should be #10 fused at 30 amps. Test the voltage between the 2 hot wires. It should be 220. Between either hot wire and neutral or ground should be 110 volts .. IF YOU DON"T KNOW WHAT YOU ARE DOING CALL SOMEONE ELSE. This is very dangerous if hooked up wrong.
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Dacor cooktop Model # SEC30-1C
is this a smooth top? glass? if so gently scrape with a razor blade yes a razor blade. then buff with cerama bryte or comparable cleaner available @ walmart or home depot etc..
Apr 22, 2008 | Dacor Millennia ETT304 Electric Cooktop
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Electrolux 30" Electric Hybrid Induction/Radiant Cooktop - Stainless-Steel/Black Logo
24 people viewed this question
Top Electrolux Cooktops Experts
Paul Carew
Lawrence Oravetz
gbob59
Are you an Electrolux Cooktop Expert? Answer questions, earn points and help others
