Question about Dryers
Ctd80 hotpoint dryer error code f10
How do i fix this problem i know error code f10 means Common of heater open or one shot open
  • 7 more comments
  • debbie66 Oct 09, 2007
    how do i fix this problem
  • idonit Dec 31, 2007
    Same problem and CRASH800's solution worked a treat, though I used a paperclip rather than a pin!!
  • Anonymous Jan 10, 2008
    i had exactly the same problem and the extended warrenty had run out on my machine, and was thinking i was ging to have a big bill just after xmas but found this and my tumble dryer is working perfectly again
    thanks
    mate
  • kelly applewhite Mar 04, 2008
    My dryer has the F10 error please help
    I have the F10 error message and cant get rid of it please help?
  • Anonymous May 28, 2008
    Many thanks!
    For ours, we only had 2 thermostats, it was the brown one with a hole in the middle, it clicked when pushed with a paperclip.
    Thanks again!!
  • seymocol Jul 26, 2008
    F10 fault code
  • Anonymous Sep 28, 2008
    f10 on dry when ever i put it on it reads this after a few mins of working
  • angie924 Feb 22, 2009
    Hi there
    I have the error code f10 as mentioned above,i have also removed the back panel and see the 3 round thermostats,however they are all the same color,silver ? and there are no holes in any of them,any idea what i can do ...i cant live without my dryer,please help...thanks
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Apparently a common fault on these indicit based driers.
it worked on mine
Posted on Oct 28, 2007
Any one ending up on this page Try Crash800 solution,, worked great for me "Many thanks to him" as not had the use of the dryer for a good few days because of it.....A++++++++ for Crash800
Posted on Feb 24, 2008
  • 4 Answers
** remove power from ANY appliance before comencing investigation **
On ours, the thermostat with the hole could only be found by removing the screws that hold the heater assembly, as the hole was not vissible without doing this (it appaered that there were only two silver thermostats, when in fact there are definately 3.
pushing a pin through the hole gently until a click was heard and then reassebling the dryer cured the F-10 and F-8 issues.
Posted on Jun 24, 2011
Thank you soooooo much crash. I'm a mere feeble woman and short of cash too, so calling out a repairer was out of the question. I've followed your instructions and its working perfectly. I am sooo proud of me too for biting the bullet and tackling this myself. xxx
Posted on Nov 14, 2009
Many thanks, this was very helpful.
Side note, ours only had 2 thermostats, in our case it was the brown one on the left, with an hol in the middle, this clicked when pushed with a pin.
Thanks again
Posted on May 28, 2008
I had an hotpoint ctd85 that triped the rcd, found the mica holding the heater elements in place was damp (beyond repair) replaced with new heater now ok. prior to that i also re-soldered most of the joints on the control pcb this seemed to cure the fault codes associated with the heater relay
Posted on Apr 14, 2008
Thanks repair took 10 min and one screwdriver.
saved me AU$100.00
Posted on Jan 09, 2008
Hotpoint aquarius super silent WF630 FAULT CODE F02
[/spoiler] [spoiler title="EVO1 Washing Machines and Washer Dryers" open="0" style="2"]
  • F01 - Short circuit motor triac*
  • F02 - Motor jammed tacho detached*
  • F03 - Wash thermistor open/short circuit*
  • F04 - Pressure switch jammed on empty*
  • F05 - Pressure switch jammed on full*
  • F06 - Program selector error*
  • F07 - Heater relay stuck*
  • F08 - Heater relay cannot be activated*
  • F09 - Incompatible eeprom*
  • F10 - Pressure switch not sensing correctly*
  • F11 - Pump cannot be activated*
  • F12 - Communication error*
  • F13 - Dryer fan or dryer thermistor faulty*
  • F14 - Dryer element faulty*
  • F15 - Dryer element relay faulty*
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock*
Error Codes Hotpoint Service
Aug 24, 2015 | Hotpoint Washing Machines
What is a f12 fault
F02 - Motor jammed or fan blocked*
F03 - Front thermistor open/short circuit*
F04 - No pump piloting*
F05 - No feedback from the pump*
F08 - Static heater relay with contact welded closed*
F09 - Eeprom is not programmed or not functioning*
F10 - Common of heater open or one shot open*
F11 - No pump connection*
F12 - Communication error between board*
F13 - Rear thermistor open/short circuit*
F15 - Dynamic heater relay with contact welded closed*
F17 - Master relay welded closed* - See more at: http://www.hotpointservice.ie/help-and-advice/error-codes/#sthash.nR8Jb1cP.dpuf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_32f4b76dad4781c4
Dec 12, 2014 | Hotpoint Dryers
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
F10 error code on Hotpoint ctd80. How do I fix ? Thanks
remove 2nd largest panel on back of dryer then remove the heater unit (two small screws) from inside panel,on the top of this you will see two small units with wires going in and out both sides looking closer one of these units has a small hole using a pin push it down into hole this resets thermal cut out,you should hear a small click.
Feb 02, 2009 | Hotpoint TDL15 Electric Dryer
Hotpoint ultima tumble drier condenser has F 10 error code
Error code F10 means common feed of heater or thermostat open circuit.
You need to test the thermostats and the heater element for continuity.
You need a multimeter to do this, assuming you know how to use a meter,then set it on the ohms range for continuity, remove one wire from each stat, and test with meter across terminals of stats,
You should get FSD if stats are o/k.
If you don't, then you need to replace both stats, even if only one is faulty.
It is unlikely to be the element that is faulty, as they rarely fail.
Plz rate my solution.
Thanks
Jan 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Dont know what the fault codes are for my Hptpoint Dryer CTD80
Hi.
F10 indicates that the heater is open circuit, or the thermostat is faulty, more likely to be open circuit thermostat, you should replace both thermostats.
Also make sure that you clean the filters regularly
This should solve your problem.
Nov 20, 2008 | Hotpoint Dryers
Hotpoint ctd 80
The error code F10 is common of heater open circuit or one shot thermostat open circuit.
F8 is indicating static heater relay contact welded closed.
You need to call an engineer.
Oct 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint CTD80 Tumble Dryer F03 error
hiya
sounds like you will need a thermostat kit and possibly a heater unit, if your getting them shipped to oz you will probably use them. i would change the thermostats first as this will more than likely be the cause.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj.
p.s if its still broken this time next year i'll come and have a look just waiting of my visa :)
Jul 24, 2008 | Hotpoint Aquarius WD63 Front Load...
Condensor hotpoint ctd80 drier WON'T GET HOT
Check vent from dryer to outside.
May 09, 2008 | Dryers
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
4,753 people viewed this question
Top Dryers Experts
Marvin
Marvin
