Question about 3Com Computers & Internet
3com 5500g switch password recovery - 3Com Computers & Internet
Decrypt 3com password
Use a brute force password solver or at best do a reset
Dec 05, 2016 | 3Com Computers & Internet
Recovery password 3com wx2200
Try this http://www.fixya.com/support/r11153882-general_routers_reseting
Jan 14, 2014 | 3Com WX2200 (3CRWX220095A-US) Wireless LAN...
I forgot ip address and password and want to factory reset
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following:
1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max.
2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power.
3) Once the switch has rebooted, enter a new password for the "admin" user account.
4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user.
Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
Hi, I have two VM citrix servers that i have load balanced using windows NLB. My users are on a different subnet so I have the load balancing configuration set to Multicast mode. (I have a second nic in...
I have not worked with 3Com switches only Cisco, but I thought I would post this as I found it when googling:
multicast routing-enable pim
on the vlan interfaces:
interface Vlan-interfacex
ip address ***.***.***.*** ***.***.***.***
igmp enable
pim dm
Those commands should help you get multicasting to work. notice, Vlan-interfacex means you will have to do it for each Vlan you created. Some switches do not include multicast support in their base models but make you buy additional licenses to enable it. Cisco is like that, not sure about 3Com.
Chris
Sep 08, 2011 | 3Com Switch 5500G-EI (3C17261) Network...
I forgot my admin password on my 3com baseline switch 2226-sfp. i can't remember. Can you please help mo to reset my baseline switch to reset the password only. Thanks jenry
If it's the Power Plus (3C16475BS) model, there should be a reset button inside a small hole on the back. "10 - Recovery Button" Inserting a paperclip or similar to reset. If it's not the Power Plus model and is in fact (3C16475A), this is an unmanaged switch, with no administrative capabilities. You don't need a password.
http://www.3com.com/products/en_US/detail.jsp?tab=features&pathtype=purchase&sku=3C16475BS
Feb 25, 2011 | 3Com 3C16475A Baseline Switch 2226...
How to rest t
Connect the switch with a null-modem cable
In windows, hyperterminal , To enter into Password Recovery Mode:
login: recover
password: recover
Turn the power off (hard reset) within 30seconds
Re-enter the password twice.
Feb 23, 2011 | 3Com SuperStack 3 4228G (3C17304-US)...
Hoe do you reset a 3Com Superstack3 3870 to factory defaults?
Username: recover
Password: recover
*** Password Recovery Mode ***
The administrative password will be cleared if a hard reset operation is
carried out on the device within 30 seconds.
If a hard reset operation is not carried out during this period, the device
will return to the CLI login prompt.
Nov 09, 2010 | 3Com (3c17462)
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Computers & Internet Logo
23 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
