Question about Bosch Washing Machines
Cl error cod bosh avantixx 8
My bosh washing machine avantixx8 keeps showing an error code CL, i dont know how to fix it
  • 1294 Answers
SOURCE: LG Intello washing machine, model: WD12235 Front Load
Why dont you people read the user's manual? You wil learn abt your machine, to a certain extent. Try "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds. Works for other machines...............And please rate me if helped................
Posted on Jan 06, 2008
SOURCE: CL ERROR
"CL" means Child Lock. Press and hold RINSE+ & PRE WASH Simultaneously for about 3 seconds to de-activate.
Posted on Jan 23, 2008
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Posted on Nov 11, 2008
  • 5 Answers
SOURCE: I have an LG washing
CL = Child Lock. Press both WASH and RINSE buttons at the same time and lold for several seconds to unlock (or lock),
Posted on Jan 30, 2009
drsn
  • 42 Answers
SOURCE: TROMM Washer "CL" Error Message
THE CL ERROR CODE IS CHILD LOCK, PRESS AND HOLD THE PREWASH BUTTON FOR 3 SECONDS AND IT SHOULD TURN OFF........ BUT IF THERE ARE OTHER BUTTONS TO PRESS TRY IT OUT, THE OLDER LG'S HAD TWO BUTTONS TO PRESS, SO IF YOURS ARE THE OLDER ONES TRY IT OUT..... IF THIS HELPED OUT, PLS LEAVE A FEED BACK. I DO NOT ACCEPT PAYMENTS FROM ANYONE ONLY FEED BACKS, IT MOTIVATES ME TO HELP OUT OTHERS WHO NEEDS HELP....................
Posted on Feb 13, 2010
Error code cl
LG Washer Error Code Cl Fix. CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and that's it
May 02, 2017 | Washing Machines
My LG WM-14331FD washing machine has error code CL. How do I get rid of it please.
CL is child lock, just press the child lock labeled button for about 3 seconds. with the unit powered on.
Sep 16, 2016 | LG Washing Machines
Lg wm2140cw washer error code cl My lg washer show cl and I couldn't use my washer
CL means that your washing machine’s CHILD LOCK is ON. You can find two buttons Temp and Options in the panel.
Turn ON the machine, press these two buttons together for 3 seconds and that’s it.
It might have a little kids face above a lock key, in between the wash and rinse buttons, hold these for 3/5 seconds and it should work.
Jul 29, 2016 | LG Washing Machines
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix - ApplianceRepairLesson.com
www.appliancerepairlesson.com/.../cl-error-on-lg-washer-repair-help-lg-t...
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
www.samsung.com/au/support/skp/faq/868833
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
www.homedepot.com/.../d7064d64-8ea1-487d-9c35-a...
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
On an LG front loading washing machine, what does the code CL mean?
Hi Emma Haigh,
CL means Child Lock, please follow my below Tip on how to remove the setting:
L.G CL ERROR/CODE
Kind Regards
JEDMEYER1
* If you found this solution helpful, please rate it
Aug 01, 2011 | LG Washing Machines
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
IE is a water inlet error...meaning that the correct water level was not achieved within 8 minutes or it did not reach preset water level within 25 minutes...
CL is child lock feature which can be toggled on and off by by holding the Pre wash button in for 3 seconds.. Hope that helps...
Aug 04, 2008 | LG WM-2277HW Front Load Washer
Hai Idiots
Amber
Jun 12, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Apr 09, 2008 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
