Question about Canon F-603 Calculator
HeLp ! There is a word 'BIN' appear on the right hand side of the screen which maybe the main reason that cauz my calculator to jammed, how to solve it?
You can try to press MODE and then number 1 ... Then with DRG you can change to DEG, RAD and GRAD ... I hope it will work
Posted on Dec 13, 2007
    An expert who has written 3 tips or uploaded 2 video tips.
  • 114 Answers
That's the Binary code. You have to change it back to the Decimal code. Try to change it back with the shift and Mode buttons
Posted on Oct 08, 2007
When i ask to solve it wont let me
If it is not accessible (grayed out) then the context is inappropriate. The reason could be the misuse of the verb solve. A lot of people confuse calculate with solve.
If you care to tell us what you were trying to do, exactly, maybe we can help.
Nov 12, 2013 | Texas Instruments TI-Nspire Graphic...
I replaced new cartridge in T1-5630 and it is not printing.
the reben is not proper settings in that fitings shapes if we miss side folds the rebens is not able to run in cartrideges then it jam reben stop but matter machine go reben comes side at print cames nothing
Jan 10, 2012 | Texas Instruments TI-5630 Calculator
HP Laserjet 5200 top bin full
Hi, Remove all the papers from out put bin & check if not solved remove both side and top covers absorve right side of the out put bin flag sensor clean it with high pressure air or clean with dry cloth gently. Best of luck...Vinay
Apr 18, 2011 | HP LaserJet 5200 Printer
For instance if I have a problem of 4x+1-x=2x-13+5. how do I enter it in my T E to find wha is X
This calculator does not have a Solve function or a solver. However this example of yours is very simple that you can do it by hand. If you do not mind I will show you how to solve it. Not everything needs a calculator.
You want to solve for x. OK
  1. Start by gathering similar terms 4x-x =3x; -13+5 =-8
  2. Rewrite your equation as 3x+1=2x-8
  3. Make the +1 change side while changing its sign
  4. 4x+1 -1 = 2x-8 -1 or 4x=2x-9
  5. Make +2x on the Right hand side go to the left hand side, changing its sign in the process 4x-2x=-9 or 2x=-9
  6. Divide both members by 2. This gives
  7. x=-9/2 or -4.5 if a decimal result is required.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-30XA Calculator
How to use NumSolve on the Casio Classpad 330 Calculator Also is there a way to get back a deleted e-activity document?
Sorry the solution was posted as a clarification request. Here it is at the right place.
  1. Turn calculator ON.
  2. Look for the NumSolve icon.
  3. Tap the icon.
  4. The equation editor screen opens with the word Equation: on one line and a small rectangle on the next one.
  5. At the position of the rectangle, type in the equation.
  6. Do not forget the right hand side.
  7. Press [EXE].
All the non-numerical variables, parameters are then listed with a radio button next to each one of them.
  • Tap the radio button next to a variable and enter a value for a parameter.
  • Repeat for all known values.
  • Last, enter a guess for the unknown you are solving for and
  • set the bounds between which you suspect the solution to be.
  • While the radio button for the unknown is still checked, tap the Solve Menu at the top of the screen,
  • select Execute submenu and
  • press [EXE].
  • Alternatively you can tap the Solve at the left of the toolbar.(see picture).
If all goes well and the solution is found (this dependent of how good your guess is), the calculator returns with the value of the unknown and displays the difference
Left side-Right side = 0 or a very small number.
If the solution cannot be found you will be prompted to change the initial value (your guess) and/or the bounds. Hope it helps.
Nov 27, 2009 | Casio ClassPad 300 Calculator
I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
Nov 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
The numbers are not visible on the screen and Im not able to set the calculator on the degree mode .
First try this- press the 2nd key and press and hold the up arrow key or the down arrow on the right side of the calculator a for a few seconds and see if the curser appears - if it does - than problem solved . to set the calculator to degree mode press the MODE button and find Radain, degree and hightlight it by moving the curser over it and press enter than exit it now set to degree and press sin(30 and enter and see if you get .5 as a result it it does than problem solved
Oct 06, 2009 | Texas Instruments TI-85 Calculator
When I turn on my calculator, half the screen is blank. When I enter numbers, they show up after the blank side. Basically, the left side of my screen stopped working, and it has nothing to do with...
Since I do not see the kind of screen you have, I surmise (maybe wrongly) that the split screen is activated.
Press [MODE]. Use [DownArrow] to scroll to where is says Full Horiz G-T. Highlight FULL and [ENTER] Then [2nd][QUIT].
If that does not solve the problem
[2nd][MEM] [7:Reset][2:defaults][2:Reset]
Hope it helps.
Aug 15, 2009 | Texas Instruments TI-83 Plus Calculator
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
Half of screen blank
it may have been spoilt, TI-89 Titanium calculators are not very lasting. You may want to try the resetting all memory (2nd 6 F1 3 Enter)
Oct 17, 2007 | Texas Instruments TI-89 Calculator
Canon F-603 Calculator Logo
242 people viewed this question
old marine
old marine
