Question about Bose Lifestyle Music System Model 614810
Subwoofer and speakers no sound
Problem w/ my Bose lifestyle music system model 614810.the amp' still working but no sound from the sub and speakers. Didn't use about 3 months but when I turned it on no more sound. Pls. Advise how to fix the subwoofer. Many thanks
CLARKPINK55
  • 71 Answers
SOURCE: Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Posted on Dec 10, 2008
quang123
  • 107 Answers
SOURCE: Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Posted on Dec 16, 2008
SOURCE: bose acoustimass 25 subwoofer has no power
Honestly speaking you should probably not work on this unit yourself: "There are no user serviceable parts inside"
Even if you are an accomplished Electrical Engineer Bose will not provide the required schematics to troubleshoot and repair this unit.
Are you still undaunted . . . then if the case is the original LS-25 series, there is a hidden catch at the end of the cover furthest from the input connectors that needs to be rotated (until a plastic tab is sticking out), which you can do with a flat bladed screw driver, and you also need to remove a few screws from the bay where all of the connectors reside. Remove the two knobs from the side of the cover. Then hit the case with your fist at the far end (plastic tab) and the cover should then pop off. You may have to hit it hard, with an upward motion.
Note there is not going to be much you can do to fix this beyond replacing the fuse. (Note that the fuse may be soldered in.) The bass amplifier is op-amp based with discrete class G output stage and the twiddler amps are monolithics with discrete class G circuitry shared between several channels.
The power transformer has a thermal fuse in it as well which is not replaceable. If you play the unit loudly for long periods of time and it is not adequately ventilated it is possible for the thermal fuse to open - if this is the case you will definitely need to send it in for service.
When plugged in there are hazardous voltages present on the top PC board where the power connector is located, whether or not the unit is turned on.
Power switching is via a triac controlled by whichever front end you have CD-5? 12V should be present on the mini plug (tip I think, but might be ring) when the music center is on.
There is also offset detection circuitry that will latch the unit off should any output have more than a volt or so of offset.
For more information see following web site:
http://www.diyaudio.com/forums/showthread/t-106135.html
Posted on Mar 01, 2009
  • 9 Answers
SOURCE: Bose Lifestyle 20 system. sound from only two speaker
A lifestyle 20 system is stereo only. Two channels. Left and right.
Posted on Jun 07, 2009
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
I have a Bose powered sub woofer, which I would like to connect to a pioneer receiver, the subwoofer (model 2683) connection has a four pronged connection (yellow white red blank) and the receiver has a...
Hi,sorry but you can not connect it directly like other sub-woofers..
Bose 2683 Powered Subwoofer is part of Bose Lifestyle 5 system, Please note that you will need the 5-pin DIN cable that connects the subwoofer to the base or "Music Center". and the 4 pronged connections for its own stereo speaker output not input from another stereo..
Sorry....but if you can arrange some handy man nearby ,he may get into the DIN cable to locate the subwoofer signal 2x input leads than you can use that leads for connecting into single sub woofer out let of your system...otherwise try to sell BOSE which can easily buy brand new up to date powered sub..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
Hello, We have Bose Lifestyle 12 system. It has been working great until now for 10 years. We moved homes locally with in town. Now when I tried to hook up my system, there is no sound coming out of the...
Please check if the AC cord of Acoustimass module has a good connection to AC outlet, also check all the connections specially the cable that goes to the system control unit jack, for your reference in the link below you can see and download the manual of your Bose system:
http://www.bose.co.uk/GB/en/images/Lifestyle%2012%20Series%20II%20Home%20Theater%20System_tcm6-4071.pdf
Mar 04, 2011 | Bose Lifestyle 12 System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
AVR-1910 & Bose Lifestyle 35 setup
Bose Lifestyle (and all Bose-amplified speaker) products and their speakers are SYSTEMS and should not be split up or intermixed with other brands or models. Damage will probably result. Proprietary connectors provides a clue.
The digital audio out should work with the Bose. You could still use your Denon to drive a conventional sub in your scheme, but you would have to manually match volume with the Bose. Or go Full Monty and buy a full complement of speakers for the Denon, retask the Bose and slave its sources to the Denon.
Dec 05, 2009 | Audio Players & Recorders
Is there a current model receiver that I can puchase to drive my existing subwoofer and 5 speaker set? My Series 5 died.
How to connect Bose Acoustimass 25 series II subwoofer to Denon Receiver using factory provided 13pin cable
Oct 25, 2009 | Bose Lifestyle 25 System
Jul 28, 2009 | Bose Lifestyle 38 System
'05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
Bose Lifestyle Music System Model 614810 Logo
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
