Question about Clarion DXZ385USB Car CD/ MP3 Player
What are the color codes for the rca jacks on a clarion dxz385usb
4 Suggested Answers
  • 7 Answers
SOURCE: can i connect ipod adaptor to rca output jacks?
With out an input jack you cannot connect straight to your head unit. The RCA out puts only send a signal out. Your best bet is use an FM transmitter for your Ipod. The sound wont be as good but I can't think of another way with buying a new head unit.
Posted on Jun 05, 2009
  • 3 Answers
SOURCE: I need the wiring diagram for my new Clarion
Brown wire-Phone mute Yellow 3A-Bus power lead Yellow 15A-Memory backup lead Red-Power lead Blue/White-Amp lead Black-Ground Orange/White-Illumination lead Blue-Auto antennae SPEAKERS(black strip is -ive) gray+gray/black-front right white+white/black-front left purple+purple/black-rear right green+green/black-rear left
Posted on Jul 06, 2009
SOURCE: My clarion dxz385usb has no sound.
Check to make sure exposed wires aren't grounding themselves out. I just had this problem and after 2 days of re-wiring and re-checking almost every wire I finally found the culprit. The Remote wire from my amp has become exposed and grounded itself out. Unit worked fine, same problems you are having.
Posted on Aug 25, 2009
How do I change the color display on my clarion DXZ385USB
You can't, this model has a fixed color. The illumination is done using tiny LEDs (4 red LEDs for the buttons and 2 white LEDs for the display).
Oct 22, 2015 | Clarion Car Audio & Video
What is the color code for the rca jacks
Yellow is composite video, red and white audio.
http://en.wikipedia.org/wiki/RCA_connector
Feb 01, 2011 | Clarion CZ-509 Car CD/ MP3 Player
My battery died. Do I need a reset code for this model to work?
i shouldn't think so. unless it is an oem unit, clarion doesn't require a security code.
Jan 05, 2011 | Clarion DXZ385USB Car CD/ MP3 Player
I have no sound
if you have no sound from the speaker wire outputs most likely your channels are blown wich is common if you insist on using the radio you can hook up an external amplifier with the rca outputs on the back of the radio and run the speakers to the amp instead this will give you amplified sound but it will give you sound out of the radio
Feb 28, 2010 | Clarion DXZ385USB Car CD/ MP3 Player
Clarion radio showing 8 error
If you have a BMD button, then press it and that might reset it from 8 ERROR  straightaway.
If not ,then to reset it , leave it SWITCHED ON...UNDISTURBED for as long as it takes (Could be several hours but quite often only an hour or two)
Sep 21, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Just installed my dxz385usb. powered up and got
Check to make sure that the speaker negative and positive leads are not touching. I had the same issue on a 97 maxima, and found the rear speakers so damaged that the (bare) leads on the speaker itself were touching the basket of the speaker, shorting the whole thing out. I disconnected the rear speakers and it started working.
Jul 04, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
I need the wiring diagram for my new Clarion dxz385usb
Jul 02, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Jun 13, 2009 | Clarion DXZ475MP CD Player
Clarion DXZ385USB will not play from the usb input
It is not compatible. I had the same receiver and mp3 player. according to the Clarion website, an "ERROR 5" is the message for a compatibility problem. You probably got an "ERROR 2"(format problem) when you had the player plugged in and then cycled through the sources(that's how I received the error).
I have since bought an Ipod and the USB input works just fine. Clarion says the deck is MTP compatible, but it will not run a lot of MTP devices. Only Ipods and certain memory sticks. The Creative Zen Vision M is read as an MTP device when it it plugged into anything like a computer, Xbox 360, and the Clarion USB receivers. The Clarion units even attempt to read it as an MPT device, but will not play. It is not an issue with the receiver or the MP3 files. The Creative Vision M is not a compatible device, sorry.
May 29, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
I just got a Clarion DXZ385USB deck installed, but the screen does not appear blue as in the product pictures. It is dark and barely readable. Dimmer is turned off. Any ideas?
I didn't have to connect the illumination lead. If you have the battery wires(yellow) connected, the screen will light up pretty bright. When I connected the illumination wires(orange), I got the same dim screen light effect.
Apr 17, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Clarion DXZ385USB Car CD/ MP3 Player Logo
37 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
