Question about Garden
I have a John Deere stx30 that when I try to start it it just clicks. I use to be able to jump it and now it won't let me. Could someone please help me!!!
    Sergeant:
  • Garden Expert
  • 417 Answers
I'm assuming, since no one else even mentioned this, that you know without a doubt that the battery is good, and fully charged, yes?
Posted on Nov 21, 2013
  • 3600 Answers
SOURCE: John Deere hydro 185 When I try to start
You have a bad disk in the starter solenoid pull the starter and go to a shop and buy a new solenoid or flip the disk in the solenoid and sand the two contacts so that it will make contact.
Posted on Jun 12, 2009
  • 66 Answers
SOURCE: Need diagram for belt replacement for John Deere
Posted on May 30, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
GodBlessU
  • 3513 Answers
SOURCE: I have a John Deere
Hi
Unhook the fuel pump feed to carb line and place it over a gas can with ignition disabled to see if it is pumping any fuel at all. If you are getting fuel past the filter and pump (should be low pressure) your next bet would be to check the carb itself. Many smaller motors that aren't run often can develop deposits or contaminants that clog small ports or jets in the carb and prevent fuel from making its way into the motor. If you have any available you may want to try spraying a little starting fluid into the carbs while cranking to see if it will help it turn over.
However if you are getting gas out of the bowl, then it can't be a plugged fuel filter. It could be bad needle-valve or blocked passage. Take the carb apart and soak it overnight in Lacquer thinner then blow it out with an air compressor. The float should be set slightly higher than level with the carburetor upside down.
Also check this helpful link to troubleshoot your issue:-
http://www.lawnmowerman.tv/Troubleshooting.asp
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jul 19, 2011
  • 640 Answers
SOURCE: have a john deere sabre
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Posted on Aug 07, 2011
Snow blower attachment M02462X052302 will it fit a GT262 tractor? Attachment and tractor are John Deere.
I see snow blowers as an option but 262 is not included in the list.
It says it fits 212,F510,F525,GT275, Lx172,LX173,LX176, LX178,LX186,LX188,LX255, LX266,LX277,LX277 AWS,LX279,LX280,LX288, LX289,STX30,STX38,STX46
Not to say you can't make it fit but it will take some work.
Best,
Joe
Sep 30, 2016 | Garden
Why does starter click and not turn engine
when that happened with our car we found out the our car needed jumped to start if you don't have jumper cables someone you know might have some after we jumped our cars it worked just fine. side note if that doesn't work you might check your gas levels.
Jul 31, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Stx 30 Starts, runs until attempt to engage electric clutch.Thanks
I have a John Deere STX30. I can start it, but when engage into gear it die completely!
Jul 06, 2011 | John Deere Lawn Tractor Seat F710 F725...
SOME ONE GIVE ME THE UNLOCK CODE FOR JOHN DEERE DRIVE GREEN PLZ
if someone is iknd enough to E-mail me the unlock code of john deere drive evergreen to shleroux@gmail.com
Tanx it will really be nice!
Sep 18, 2010 | John Deere Drive Green Farming Pc Game...
John deere 316 won't start
not sure but i think check the battery i am fighting the same problem and i jumped it from my truck and it runs fine i am looking for a battery tto dya
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
238 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
