Question about LG WM-2277HW Front Load Washer
Our LG WM2016CW Washing machine is having control problems. The timer is randomly resetting to odd times for example it may have only 20 minutes left and then the timer will reset to 3 hours and 59 min. We are also getting a door error. Would somemone please provide some guidance on determining the cause. The timer resetting to these odd times is leading me to think it is a problem with the controller. There are two controller boards, one in the back and then one in the front that is the user display. Which one controls the time? Thank you for the help.
  • LG Master
  • 8,220 Answers
You must either be using the wrong stuff or adding too much detergent. Them washers have a built in program to fix a suds problem by changing the time and giving the program an opportunity to correct on it's own. By running a series of mini washes and whatnot to get the soap out of the washer. When too much soap is used it cause the motor to overheat. This is noted by the control and recognized as sudslock. Look on my DIY Youtube about page. I have a bunch of links to various blogs, manuals, and notes on what to check as well as a bunch of how to videos.
Posted on Nov 20, 2013
ngfam1
  • 639 Answers
SOURCE: LG Washer will not drain
Dear LIVINEASY,
ngfam at you service!
CALL THEM UP AND DEMAND THEY FIX IT AND DO NOT PAY ANY MORE TIL IT'S FIXED!
I HAVE STOP CHECKS AND STOPPED CREDIT CARDS
AFTER YOU PAYED! THE CREDIT CARD COMPANY IS ON THE CONSUMERS SIDE NOT THE MERCHANT!
iF YOU PRESENT IT AS THEY CAME OUT ON THIS AND THAT DATE CHARGED AND DID NOT FIX IT!
THE CREDIT CARD COMPANY WILL REMOVE THE MONEY YOU PAYED FROM THE MERCHANTS ACCOUNT AND CREDIT YOU BACK!
IT HAS HAPPENED TO MY BOSS AT THE JOB EVEN WHEN HE WAS IN THE RIGHT! HIS CUSTOMER LIED TO THE CREDIT CARD COMPANY AND HE GOT SCREWED AND CAN NOT DO ANYTHING ABOUT IT!
YOU ARE FOR REAL.
Yes sounds like you need GOOD service!
NEXT TIME Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
  • 489 Answers
SOURCE: LG INTELLOWASHER DD 7KG
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
Posted on Sep 29, 2008
SOURCE: LG WM-1285FHD Error Code 'CL'
The "CL" code is not an error! This means "Child Lock"!
To unlock a washing machine you will press and holding within 3-5 sec two button, marked "child lock".
And happy day will come! :))
Posted on Dec 19, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
SOURCE: tromm washing machine, front load from LG
I am getting an OE message during the washing cycle in my LG Tromm washing machine. What does it mean and how can i fix the problem?
bscavella@sbcglobal.net
Posted on Feb 17, 2009
Washer from flashing 1E & leaking
LG Washing Machine Displaying Fault Code IE or 1E WM2016CW WATER INLET ERROR // Water not entering washing machine correctly
The manufacturer has assigned this error or fault code to indicate that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 02, 2015 | LG WM2016CW Front Load Washer
What are the most major issues with lg wm2016cw washers?
all washing machines suffer from same things.overloading throws balance off stuff in pockets finds its way to the pump too much powder is used causing blockages and soft water areas cause elements to fir up with limescale.eventally motor brushes wear.but theyre cheap to replace
Aug 05, 2014 | LG WM2010C Front Load Stacked Washer /...
Washing machine won't turn back on.
unplug it for a few minutes then plug back in
Jul 28, 2014 | LG WM2016CW Front Load Washer
My lg tromm washing machine will not start wm2016cw
Hey there! My washer just did this and i stepped away for about 10 minutes with it unplugged and once i came back, it worked! Just give it some time to relax and restart :)
Nov 28, 2012 | Washing Machines
The lights on my LG WM2016CW will not come on.
While looking for the fuse, which I could not find despite opening up the machine from the back (and vacuuming underneath--yuck!), I left the washer unplugged for about 30 min. From reading other forums and such, I realized that unplugging for a little while is often the solution because the prolonged (at least 5 min) lack of power triggers the system to reset. Sure enough, when I went back to plug it in and give up for the night, the thing worked fine. Good luck to anyone else out there!
Aug 24, 2009 | LG WM2016C
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Washer time-down problem
Check to see if your machine is connected to cold water, it should be. The problem could be the electronic thinks the machine is always connected to cold water at about 20 degree c. if connected to hot, the time drop if the it would take to heat the water to the incomming temperture Good luck
Aug 14, 2007 | Miele Touchtronic W1213 Front Load Washer
LG WM-2277HW Front Load Washer Logo
102 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
