Question about Admiral Refrigerators
My Admiral mullion is hot
The Mullion is hot. And I usually can hear it defrost(water run in the tray), but have not heard it defrost in a while.So its not defrosting, And the frige and freezer are cold. Admiral Modal# LTF2112ARW Serial#54466803 LJ
    Champion:
    Habit-Forming:
  • 275 Answers
Probably the defrost element has failed, ice & frost will continue to build up & it's ability to cool will deminish over time. Has to be checked & possibly replaced.
Posted on Nov 22, 2013
woodchuck789
  • 4059 Answers
SOURCE: Condenser fan runs all the time is this common?
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Sep 15, 2009
  • 50 Answers
SOURCE: Mullion between freezer and refrigerator is extremely hot.
They rarely use 'heaters' anymore. If there is a heater there will be somthing like a 'energy saver' option to turn it off. More likely it is a mullion loop that is part of the sealed system tubing. The harder the frige works the hotter that area will be. So if the inside temp rises so will the temperature of the mullion. Start by checking your frige and freezer temperatures with a thermometer. The freezer should be between 5-10 deg ABOVE zero and the frige should be about 35 or 36 deg. Also check that the condenser is not dirty. The condenser is the coils that are usually underneath the frige. They should be cleaned at least annually. Also while you're under there make sure the condenser fan is running. You should feel a little air movement and possibly hear it running from the front under the doors. If it's not running you'll need to find out why, but would usually be a problem with the motor. Also there was a carboard panel on the back at the bottom of the frige from the factory, that panel HAS to be in place to direct air across the condenser and not back behind the frige.
Posted on Jul 19, 2008
AGUSYUSTIARA
  • 116 Answers
SOURCE: freezer & refrigerator not getting
Ok, I'll give quick solution for you. Tell your problems, I can confirm the problem actually comes from the freezer, due to excessive clotting in the freezer, precisely at the cavity insulation or air ducts from the freezer to lower the freezing container is covered by ice. so that the cooling in the lower container is not maximal.
How to repair:
If you understand and know where the refrigerator TIMER. you can set the timer to the defrost function. sign is the compressor will stop when the timer is set to defrost, the ice melting process by a part called HEATER , will occur in the Freezer.
If you do not understand, the easiest way is, Unplug your refrigerator electric outlet and allow you to not use the fridge for a while until you confirm yourself all the ice frozen in the freezer had melted. can be seen from a water reservoir that is located under your refrigerator. usually a tray that can be withdrawn. Ok then, hopefully this solution can help you.
You can see my detail solution for common problem with All refrigerator in my Blog : http://trend2download.blogspot.com
Posted on Aug 09, 2010
heatman101
  • 43501 Answers
SOURCE: hotpoint FFA71 frige/freezer red light on freezer
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 15, 2011
SOURCE: admiral ltf2112arw bottom is warming and top is
3 possibilities, depending on age. 1. Refridgerant is leaking, 2. The compressor is faulty or 3. the thermostat is faulty.
Posted on Sep 28, 2011
I have a Kitchen Aide KSRS25ILBT02 Side by Side and the metal strip (mullion?) between the freezer and the refrigerator is hot to the touch. Hot enough to cause a burn if you leave your finger on it for...
You have a defective defrosting strip. A hearing element that warms the side of the fridge to melt ice that collects. Your fridge is dangerous to operate. You have a possible short in the defrost system that can electrocute you. You should unplug immediately. I am SERIOUS.
Aug 03, 2014 | KitchenAid Refrigerators
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
Is it normal for the outsides to get very hot
No. If you feel the sides getting hot, it usually means that the ref. isn't cold enough inside. There us either an electric heater or a pass of the hot gas from the compressor around the edges of the doors as well as the mullion between them. If they feel hot, it's too warm inside.... Check the ice cream: It's the 1st to go.
Oct 25, 2009 | Frigidaire Freezer Refrigeration White...
Center strip between doors on kitchenaid kscs25inbt00 gets hot. I replaced the compressor fan motor and saw that it spins 3 or 4 times when fridge is plugged in, but it wont come on again no matter how hot...
That heat strip is in all refrigerators that don't want condensation rusting them out. It's called a mullion heater and there are several of them around the door.
Find the defrost timer and advance it a few clicks and the compressor should come on. If it doesn't let us know what happened.
And if your fridge has an Economy switch, it is there so you can turn the mullion heaters off.
Sep 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Condenser fan runs all the time is this common? Also mullion between doors is hot to touch. Cleaned coils mullion still hot.
Sep 15, 2009 | Refrigerators
I have a GE Top Freezing Refrigerator. The model is GTS12BBMBRWW, if that helps. The refrigerator is constantly leaking. This is because ice constantly accumulates on the top wall of the...
Thanks for listing the complete model number.
Look behind your refrigerator for a tube which comes out at about the level of the top of the fresh foods section, right in the middle, and runs down to the compressor area. Remove the tube, clean it out, clean out any blockages you see in the hole you can now see in the back of the refrig, then replace the drain. It looks like your model has exterior condenser coils on the back. The tube is behind those coils, comming right out of the back wall.
Any blockage / restriction in this drain will cause the defrost water to stay inside the freezer and eventually find it's way into the refrigerator section. (after builing up enough ice to cause the fan blade to hit on it, making alot of noise, or even possibly block the fan blade from turning inside the freezer) If you don't want to dissmantle the entire floor of the freezer to manually defrost the entire refrigerator, you may have to unplug the refrig for an extended time to let it defrost itself. This would take up to several days. It is also possible to speed this up by manually putting your refrigerator into a defrost cycle, although one defrost cycle would most likely not be enough to completely defrost your refrigerator at this time anyway. (when I repair these, I put them in manual defrost and dissassemble to fully melt all the frost and ice off the coils, which are located in the floor of the freezer section of your model) (the defrost control is located at the back center top of the refrigerator section, and has a plastic slotted peg which can be SLOWLY turned with a slot blade screwdriver until it clicks once, resulting in the refrigerator stopping while it turns on the defrost system. It will advance out of defrost in about a half hour. Refrig must be plugged in and turned on for defrost to work.)
Hope that is enough of a suggestion for you.
Aug 16, 2009 | Refrigerators
Jul 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
155 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
