Adcom GCD 575 disc tray will not open. What can I do?
The disk tray will not open, will not slide out. The front panel shows "E", probably for Error. And ideas?
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Disk intialization/read
It will require a tech to open and clean the laser lens and change the drawer belt.
Posted on Apr 01, 2009
Adcom GCD-575: This unit has been the best performing player I've ever owned. After 15 years there is a problem. After insertion of a disc there is a spin up of the CD but no data is reflected/read within...
Your laser mechanism has lost its ability to focus on the surface of the disk and can no longer read the data. Needs to be replaced since repair not cost effective.
Jul 04, 2017 | Adcom Audio Players & Recorders
I am being told to stick a paper clip in the hole in front of the tray but there is no hole. I can't find the hole. Where else can I stick soomething in?
Generally there is a small hole under the tray. (The tray is where the disk sits in)
You may have a eMachines desktop computer, where there is an outer door which flips down, and the tray slides out.
Ease the outer door down, and see if the optical drive unit (CD/DVD drive) has a small hole under the tray.
If not then unplug the computer from power, observe Anti-Static Precautions, and open the computer case. Remove the Front Panel. (Plastic front of computer. Now remove the optical drive, and open it up.
I need the Model Number of your eMachines to be more detailed.
Post in a Comment.
Regards,
joecoolvette
Jun 22, 2011 | E-Machines emachines (emachinees) CD-ROM...
GCD-700 does not turn on. Internal fuses OK
If the fuse is intact the fault must be checked from the power supply to the main motherboard section.
Check if the power supply works, if not check the SM drivers .Click the link below;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 17, 2011 | Adcom GCD-700 5-Disc CD Changer
Washer stops and error code sd ( or 5d) shows
Hi, the error code is not 5 D it is "S" as in Sierra d. The letters stand for Slow Drain. I had this code and it was fixed in 5 minutes or less. Simply remove the bottom panel from the front of the washer. In the lower right hand corner, there is a tray to catch any items that may slip past the boot on the door seal. Slide this tray out and clean it. You will be amazed at what is in there...money, bobby pins, socks. Re-assembe the washer and presto.
Take care
Jun 15, 2010 | Kenmore HE2 Plus Front Load Washer
The printer is showing that paper jam but there is no paper in the printer.
Open the tray in the front and remove the toner cartridge, open the back panel and make sure that is is clear as well, and then slide open and closed the paper tray. Now reinsert the toner.
For some reason when this thing jams, if there isn't an actual paper jam then you have to check every panel before it will let you move on. You don't even have to remove any paper half the time...just open and close each panel and remove-reinsert the toner.
May 12, 2010 | Brother MFC-8220 Fax
Problems with disk tray
there ia a runner it slides on make sure it is not cracked'
May 01, 2010 | Microsoft Xbox 360 Console
I need to replace the laser assembly on a ADCOM GCD-750
I thought it used a KSS-240 which is a Sony laser.
# will be on the laser and Mcm has it for I think $35
Apr 16, 2010 | Adcom GCD-750 CD Player
I cannot open the door of my computer to get disk out
On the front panel below the tray that slides there is a tiny hole.
Straighten and insert a paper clip, apply a little pressure and the tray should unlock slide out.
Oct 11, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My DVD drive does not open
Yes, there is a manual way to open it. On most DVD players there is a small hole underneath the door. Push a paperclip in there until the door pops open a little. Then, pull open the door and remove your disk.
May 29, 2009 | Philips DVDR 520 (DVDR520) DVD+R Storage...
Need manual for both Adcom CD players I own GCD-750 and GCD-575
For the owner's manual for this legacy(old) unit go to;
http://www.adcom.com/data/manuals/gcd_750manual.pdf
For $350 you should be able to buy 5 new units- at least.
Apr 02, 2009 | Adcom GCD-750 CD Player
 Grubhead
Grubhead
