Question about Toshiba TP50G60 50" Rear Projection Television
Ted light In front flashing ans Tv ont open - Toshiba TP50G60 50" Rear Projection Television
    Champion:
  • 213 Answers
Check the stk 392-12- or 110 if the stk are bad the set will on turn on at all
Posted on Nov 21, 2013
TV won't power on
Could be an open internal fuse or power supply failure
Jan 03, 2017 | Philips Televison & Video
Does an ONT Support Routing?
Query the ONT nameplate to determine whether an ONT supports routing. If "gateway HGU" is marked on an ONT nameplate, the ONT is of the gateway type and supports routing. If "bridging SFU" is marked on an ONT nameplate, the ONT is of the bridging type and does not support routing.
Apr 19, 2016 | Cell Phones
Ted light at bottom right corner blinking and can't get TV to turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Televison & Video
Display backlight solution
Possible failure in the panel board as the LED's tracks could have been damaged. It is ideal to open the phone and get access to the front panel. Check the LED's by using a multimeter , it will light up in the low range. if so the back light must work unless a track has opened up ont his high density board. sometimes the plated- through holes would loose connection. if so you need help to concur and estimate.
Apr 11, 2011 | Nokia 6303 Cell Phone
I just changed the oil pan gasket on my 1998 Lincoln Navigator. It still leaks oil when running. The leak looks like it's coming from the top of the front 2nd bolt on the passenger side of the oil pan....
You might want check and see if the valve cover gasket on that side is leaking and making its way down there. It could also be coming from the rear of the intake manifold. You are going to need an inspection mirror and a flash light to see every where.
Jan 31, 2011 | 1998 Lincoln Navigator
I HAVE A SONY TRINITRON TV MODEL KV-24FS100 THAT WONT TURN ON. THERE IS A STAN BY TIMER LIGHT THAT FLASHES IN A SEQUENCE OF 4 TIMMES
hi,
Your tvs vertical scanning side have some problem. 4 blinking indicates that( self diagnosing system). may be ur vertical scanning out put ic or transistor what ever used may be faulty or my be chance for any dry soldering in the vertical scanning section. for rectifying the same u have to open ur tv. u can easily find out the vertical scanning section. just follow the two thin wire running from the yoke( big coin in the picture tube neck, there may be four wires u have to follow the thin wire normally in color green and yellow) it will go to the main circuit board . trace the track ont board where it go. it will end in the vertical scanning section. normally there will be an ic. check for any dry soldering in its pins. if not replace the same with a new one with the same number. also check the electrolytic capacitors near the ic. may chance to become leakey
ok
Dec 27, 2010 | Sony Televison & Video
WS-55859 Won't Turn On
this is a job for experienced tech most of the problems are rela ted to convergence IC's in this case
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Samsung hc-p4741w flashing red light
That sound is made by the power supply who's gooing in protection mode due to some overcurent in secondary. Could be many reasons: conv. amp. IC's, video amp.IC's etc. In my opinion more then 70% chances to be the STK for convergence. Need to be troubleshooted by a tech.
Dec 07, 2007 | Samsung HC-P4741W 47" Rear Projection...
Temp ted light blinks twice then turns off tv
Your lamp might be bad. Also, it is possible that the lamp door is not closed.
Nov 21, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
