Question about Coby Kyros Tablet
Netgear58 is saying authentication problem, how do I get my wi-fi going again
Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Apr 13, 2015 | Nextbook Premium 8 Se Android
My polaroid tablet model a7 will not authenticate and allow me to go on internet using wi-fi
Try it with a different router. Use a friends. Your router may have to be adjusted.
Go on the manufacturers web site and see if your problem is listed.
Jan 08, 2015 | Polaroid Tablets & eReaders
I can't get no is 9" tablet to work on WiFi. It connects and says connected but won't pull up authentication screen to sign on to network so I'm not able to fully use internet
try turning the wi fi off on the tablet and then turn the wi fi back on and try to reconnect.
you may need to set up the encryption. It could be set on WPA2 and the tablet may not cope with WPA2 may need to use WPA1 on router .
Jan 04, 2015 | Tablets & eReaders
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
When I try to connect it says authentication problem
It appears that the wi-fi you are attempting top connect with requires an authentication code. If you are connecting at home, it is the passcode for your router. if a business or pay for service system, you will need an account to connect.
Nov 08, 2014 | Tablets & eReaders
My new Nexus 7 wont go past the "Select Wi-Fi" screen although I have set the Wi-Fi up
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Oct 04, 2014 | Google Nexus 7
How to connect my tablet to wi-fi
Authentication often means "password protection" for the specific wifi connection. Usually your software will present a "dialogue" box telling you a password is necessary and give you an opportunity to enter one.
Jul 31, 2014 | RCA CA 7" Tablet with 4GB eory 28458515
Cant connect to internet
Well, I may be an 18 yr. old and I may be no wiz but I'm big into computers and there are several solutions to this. 1) If there is a password put in the wi-fi, you need to: have a device in which will be able to put in the type of security and/or put in the EXACT password. 2) Make sure it is YOUR wi-fi you're trying to connect to. And 3) If 1 and 2 don't work, contact the company of which your wi-fi was bought from. I hope this explaination was helpful for your problem.
Mar 26, 2014 | Ematic 7" Tablet Computer
Coby Kyros Tablet Logo
29 people viewed this question
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
