Question about Haier Washing Machines
Going out of balance
Machine works to the rinse or spin cycle them goes out of balance, throws all the clothes to one side, throwing machine out of balance, i redistribute clothes and it throws them to one side of drum again and again, have to rearrange them 6 - 10 plus times till it spins
    Champion:
  • 242 Answers
Could be the springs are wearing out. some haier models I have seen start the spin at full motor speed, which could be part of the problem.
Posted on Nov 20, 2013
  • 1294 Answers
SOURCE: Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Posted on Apr 14, 2007
  • 641 Answers
SOURCE: drum off balance
Open washer's cover and look for a released or a malfunction shock absorber.
Posted on Aug 11, 2007
It's either a bad suspension spring or you have a crack in the tub support.
Posted on Jul 15, 2008
SOURCE: spin cycle noise
Most likely, your pulley is coming off, my pulley mad that knocking sound for a year before the belt fell off and I had to address it. see the previous post on how to fix this issue.
Posted on Oct 26, 2008
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
My washes machine spins to slow then gets off balance an stops.how can I fix it ?
It may not be the clothes but the suspension springs and rods, counterweights etc
see pics
Jun 10, 2015 | Simpson Washing Machines
Lg turbo drum
Check if the counter balance weight is still attached. Sounds like a balance problem.
Bruno
Sep 06, 2014 | LG WM Washing Machines
A knocking noise during agitation wash cycle
could be a bad counter balance , u can remove the front panel and run a spin or wash cycle and listen to where its coming from so u don't have to replace all the balancers. on some models theres a heavy ceramic weight at bottom that at times goes bad and throws it off balance, just run it and look where noise is coming from
Jul 25, 2014 | Maytag Performa PAV2200
How do I stop my washer from shaking real bad during the spin cycle?
its all about the balance of the clothes in there, a heavier thing on one side can throw it off
Mar 10, 2013 | Washing Machines
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Will Only Rinse/Spin with little to no clothes in drum
sounds like unit is activating out of balance lever thats y it works with no load in it .possible faulty suspension rods making bowl move too much.out of balance lever is at back of inside bowl to the right. try adjusting back feet to make them about half an inch higher than the front feet .that will move the bowl away from lever giving more tolerence. see how u go please reply 4 more help
Mar 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Fisher & paykel w/machine md053
Investigate the concrete block mountings. If they come loose, the balance goes way out
Feb 03, 2008 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
