Question about Toshiba 55l6200u 55es Smart 1080p/120hz 3dp
Scree replacement Cracked front screen
How do i replace a cracked scree?
I would replace it by taking it to a shop that would replace it for cheap or I would find a family member or friend that will fix it for free.
Jun 22, 2015 | Tablets & eReaders
Cracked tv LED screen
sadly its going to be almost cheaper to replace as the scree for that model will be just slightly 1600.00 if you can find them
Jan 02, 2013 | Samsung Televison & Video
My screen is cracked on my sony ericsson vivaz
When you have a cracked screen, the only solution to it is to replace it with a screen of that exact type.you will have to see a certified engineer close to you to fix the scree.
Jul 24, 2011 | Sony Ericsson Cell Phones
Crack screen
Thank you for writing in regard to your concern about the crack scree on your phone. Let me help you with this.
First, I want to know the severity of the crack and if the crack is just outside the housing or casing, or is it on the LCD scree of your phone?
If the crack is on the LCD of your phone, then, the best thing that you can do is to bring the phone to the nearest service centre to replace the LCD. Cracked LCD can no longer be fixed because it is a hardware problem already.
Hope I was able to resolve your concern.
Jun 17, 2011 | HTC Inspire 4G Smartphone
The screen is cracked i need to replace the screen how can i order a new scree
There is no other way out than to replace the screen. Now the most important part is to get the estimate of the new screen before you can decide if this is feasible then to buy a new TV with the new formats.
So check this out and make sure you insurance covers this next time.
Dec 03, 2010 | Sony FWD50PX2/S 50 in. Plasma Television
Cracked screen
If you can get one it isn't very hard. The worst part is locating the replacement part for less than the units worth.
Oct 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
Cracked Screen
See if its still under warranty, if it is, call support and tell them.
If its not you can probably get it repaired but this might be expensive. then you best bet would be [I know it hurts] to get a new one.
Dec 22, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Panasonic tv model PT53WX54
You want to order the lenticular screen (has vertical ridges). The part number is TKG2AH50381 and you can find a supplier if you google it and then click on the shopping tab.
Nov 25, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Toshiba 55l6200u 55es Smart 1080p/120hz 3dp Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
