Question about Hasbro Playskool Kota and Pals Stompers - Triceratops
Head won't left up - Hasbro Playskool Kota and Pals Stompers - Triceratops
Left car light on car won't start Audi a six 2007
You can check the head light to see if it connected well ,and you can check if it connected well with you car .
Mar 30, 2013 | Cars & Trucks
My 2004 Chevy Impala right head light won't come
There are right and left fuses for the headlights. The dimmer switch and headlight switch provide the ground circuit.
Do you have power at the fuse ?
Feb 15, 2013 | Cars & Trucks
If my left headlight was blown does that mean my right headlight won't work until I replace it ?
No not at all head lights do not work like that it sounds like you have a bad head light switch
Nov 27, 2012 | Cars & Trucks
My 2001 dodge intrepid is making noise under the left valve cover
We seen to get a lot of those cars with that issue lately
I don't know the reason, but it won't be fixable without some
major head removal & whatever the dealers & aftermarket
have come up with to solve.
Bad engine design I suspect
Oct 10, 2012 | 2000 Dodge Intrepid
Left headlight
If the other head light works ,it won't be a fuse
Check every fuse in the car,won't take long &
the fuses will protect a complete circuit,not just
a couple head lights.
The light switch has a circuit breaker not a fuse.
Have you removed & tested the lamp it'self
No owners manual? Need that for fuses & bulbs/lamps
Sep 04, 2012 | 2001 Hyundai Sonata
My headlighs on a 2008 Maxima won't go on
is the head light switch its self ok just another thought
Aug 25, 2012 | 2008 Nissan Maxima
What's your problem?The horn won't work, the light that is supposed to go on when you open the doors won't work, the cigarette lighter won't work, and the head unit won't work
on 1987 all you mentioned are on same fuse #11 located in fuse box below steering wheel 3rd row 3rd fuse from left next to either a blank space if you do not have power windows,or next to silver circuit breaker if you do have power windows.
May 23, 2012 | 1987 Chevrolet Camaro
Left signal lights wont shut off all back running lights off
sounds like a turn signal switch on the column
Apr 04, 2009 | 1997 Eagle Talon
My HP Deskjet 400 won`t properly print a straight vertical line
check the print head belt.......belt that moves the cartridge from left to rite
check to see if all the teething grooves on the belt is intact...and that its all there..if this belt slips a teeth it wont print in a straight line....
Nov 09, 2008 | HP Office Equipment & Supplies
Hasbro Playskool Kota and Pals Stompers - Triceratops Logo
23 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
