Question about Barska Optics Optics
How can i get the front hood off of my rifle scope
Hood is so tight that I can move it
  • 243 Answers
If you can move it, you should be able to unscrew it. If you can't us a strap wrench. It has worked for me in the past.
Posted on Apr 19, 2014
4 Suggested Answers
  • 8 Answers
SOURCE: RIFLE SCOPE STUCK ON 8x POWER
If the scope's minimum power isn't 8x then it's broken. Call the customer service rep of the company and see how you can return it. Depending on the warranty they may fix it or replace it. I'm not familiar with Balfor as I don't shoot BB guns. You can move the ring around a bit, see if something loosens up, but don't force it.
Posted on Nov 26, 2008
fps353535
  • 99 Answers
SOURCE: RIFLE SCOPE WARRANTY
Here is the contact info for them. ask them :)
Please rate this as fixya :)
Posted on Apr 11, 2009
  • 243 Answers
SOURCE: how to zero Bushnell 3-9x40 scope rifle
this is a good guide:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
Posted on May 31, 2010
I purchased a Fujinon 3.5-10X50 rifle scope a few years ago and mounted it on a Remington 7 MM Mag. I am unable to pull a group less than 12 inches at 200 yards and have not been able too since installing...
It is most likely the mounts not the scope. I would just install it on the new gun and check it there. Most times a scope that wanders is the mounts. One thing with big scope is they need to be tight or the recoil will move it in the mounts. Next due to being tight when the gun heats up it can and will tweak the scope in the mounts enough to move your center. Try it in your other gun, try 3 shot groups and let the gun cool. Recheck your center. If it is good with a cold gun all is well. If it moves from one day to the next it is the mounts. If you count the clicks to recenter, come back the next day and move it the same clicks, it is the mounts. If it is all over the place, day after day it is the scope.
Jan 21, 2011 | Fuji non 4-12x42mm Rifle Scope
I have a bigcat and it will not shoot a gooup
I have one of the BIG CAT rifles and can shoot under 1" groups. First Check the gun and be sure it is tight in the stock. I had to remove the front screws and pot nylon washers under them to get the stock tight!
Second. I could shoot decent groups and the they would move! I replaced the scope mount with a better quality better fitting scope mount. Be sure it has the stop pin that fits in the hole in the top of the rifle or they will move to the back and never be stable.
Third. I replaced the Gamo scope with a Leupold 3X9 varix 2. I am not sure about the Gamo scope but while I was mounting a scope I decided to try the Leupold.
I have shot some 5 shot groups from a good rest that was less than 1/2". The factory scope mounts looked like a bad fit on the groves of the rifle and looked canted.
The best pellets I found are the PREMIER HOLLOW POINT and some of the worse were the GAMO FLATPOINT!
Dec 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
Crosshairs moved after rifle was sighted in
now then,,,did the crosshairs move or did the scope slip back out of line? if the mounts were not tight then its likley to be the scope slipping back but if the crosshairs moved were they just setteling or are they moving,,if there realy moving the scope is claped out or shook apart inside,,,how big is your rifle you put this scope on? 357mag??? i have a simmons scope on a 7.62 and on a .303 enfield rifle its ok on them?
Nov 02, 2009 | Simmons Optics
I can shoot my centerpoint scope on my .22 and it
When adjusting a scope just move a few clicks at the time, after every few clicks tap the scope with a screw driver handle. Fire 2 rounds for group tap and fire the third round it should be in line with the 2. Keep that up till on target. Let the gun sit till cold and re-fire for grouping, 2 rounds, wait then the third. To keep shooting round after round can get the reciver warm enough to wedge the scope in its bases, causing your problem.
Oct 13, 2009 | Optics
Rifle scope will not track with the adjustments
When you make your adjustment tap on the scope with a small screw driver handle a few times before you fire her. Work slow and tap as you go.
May 25, 2009 | Leupold ® Rifleman® 3-9x50 mm Scope
Simmons scope that will not stay on target
Mount the rifle with the scope and make a mark on the backstop right where the crosshairs are pointed at
Shoot several times, several shots will surley jolt the scope some.
If the crosshairs have moved much past your mark then this would indicate the scope is the issue.
If the crosshairs are still pretty well centered to the mark, its not the scope.
If at the same time your grouping looks terrible, and your scope still is on the mark, and the gun is WELL mounted, then the issue is with the accuracy of the rifle.
Make sure the rifle is mounted good for this to ba accurate .
Hope this helps
Feb 06, 2009 | Dual Electronics 6-24x50 AOE DUAL...
Cross hairs are tilted to right while scope is straight
Without seeing the rifle, my guess would be that either the rings were not tight enough or the lens came loose from the shot. It is rare depending on the quality of the scope. If the lens itself moved, it will not be waterproof or fog proof because the seal on the lens is not tight. If its under warranty then it should be replaced, if not then be care full not to get it too wet. If you had a suction cup, you could try to reposition it straight again.
Nov 28, 2008 | Tasco World Class 38154550 (15-45x50 mm)
Optics Logo
21 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Vladimir Frolov
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
