Question about Toshiba Ct-90302 Remote Control
Code for sony sound bar SA-40SE1 - Toshiba Ct-90302 Remote Control
I have a sony sound bar (SA-CT26OH) and a haier tv (32d3000)can my sound bar be connected to this tv
Refer the user manuals to both the devices to get more details of wiring. http://electronicshelponline.blogspot.com/
If you do not have the manuals to both devices, visit this site to download it in PDF. www.retrevo.com/
Dec 03, 2015 | Sony Televison & Video
Sony sa-wm500 subwoofer is crackling
If the sound is a scratchy type of sound then the voice coil has been damaged and is rubbing up against the internal magnet producing the scratching and low sound since the cone is barely moving;.
May 19, 2015 | Sony SA-WM500 Subwoofer
Sony sa ct60
My sound bar, just stopped working - when I push the power button on. It makes the red light go on for a mili second and then goes off again.
Any Ideas?
Jan 04, 2014 | Sony Audio Players & Recorders
I have a Sony sound bar mod# sa-32se1 connected to my Sony 32 in bravos, sounds great but shuts down after a few minutes of use what might be the problem
I had the same problem. I found that my sound bar can't be too close to the TV. I have my samsung TV on a platform ( not mounted) and the sound bar in front of it. In this configuration, the sound bar kept shutting off. I returned it as a faulty unit and the second one did the same thing. By chance I happened to move the sound bar off of the tv platform and the problem ceased.
Dec 18, 2011 | Sony Televison & Video
My Sony SA-WM40 subwoofer has power, but sound kicks out. I'll turn off power for about 5min and when turn power on, sound is back. Is something overheating?
Probably, or the woofer coil itself is experiencing a heat, volume or motion related short. Clean any dust or debris from the heat sink fins in the back. Make sure it has lots of space for cooling ventilation.
Mar 31, 2011 | Sony SA-WM40 Subwoofer
I need a code for my Technics receiver SA-GX100 to program remote
technics codes:4007, 4008, 4026, 4045, 4073,
sony cd codes: 5001,5002,5099,5100,5101
sony vcr: 1001; 1002; 1003; 1004; 1005
good luck and vote for if it works
Aug 02, 2009 | Televison & Video
Sa-wx700 with no sound
If you are a rock music lover, chances are the speaker has burn out. try to turn on and place your ear near the speaker and listen for humming
sound. if no sound at all, then its the speaker
Jun 26, 2009 | Sony SA-WX700 Subwoofer
Sony SA-VA10
Hi, Have you been able to locate the cable for your Sony speaker system? Thats a shame that they would take just the cable. Anyways, I have the sa-va10 model just like you. I just upgraded to a new sound system. And I have the cable. Tho, I m sure somewhere on the net, like ebay, amazon or even Sony should be able to help you. I would call them. Those speakers are not that old, and maybe Sony still has a ton of those cables in stock. Esp. since the system is only around 14 years old. Relatively thats still pretty new.
Jan 02, 2009 | Sony SA-VA10 System
Help with Sony SA-VA100, No Sound!!!
Your best bet is to actaully purchase a better CD player, which sucks because it sounds like the one that Sony sent you in the VIAO system is defective. I would contact the merchant that you purchased the system from and demand them to replace the defective drive.
I hope this helps.
Michael Lazar
http://www.audioholicblog.com
Feb 26, 2008 | Sony SA-VA100 System
Toshiba Ct-90302 Remote Control Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
