Question about Adidas Health & Beauty
Medion dental water jet hose needs replacement.
Hose is cracked and leaking
  • 1073 Answers
SOURCE: water hose leak, need to
what is the model number
Posted on May 06, 2008
SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Posted on Nov 05, 2008
  • 1891 Answers
SOURCE: How would I replace the water hose on a LG
purchase a 1/4 in line longe enough to do the job . insert in into the water valve and run it to the ice connection . this should correct problem . make sure the connectoins are tight and ck for leaks ..mm
Posted on Jul 22, 2010
  • 4350 Answers
SOURCE: 2000 Ford Taurus SES, 3.0L. Have coolant leak
I suggest that you put it back together, clean it, and pressure test the cooling system. Needs to hold 13 to 15 psi. THEN look for leaks.
Posted on Mar 18, 2011
Testimonial: "Thanks, will do. "
robertcbowde
SOURCE: On the Braun Oxyjet dental care unit the hose
Spare hose assemblies for WaterPiks are available , maybe they could be cut and spliced . . Geekoz.com
Posted on Nov 24, 2012
Is the Waterpik Ultra Cordless Dental Water Jet WP450 good for sensitive gums?
The Waterpik Ultra Cordless Dental Water Jet WP450 has pushbutton dual-pressure control system with low for sensitive gums (as well as high for deep cleaning).
Apr 29, 2013 | Health & Beauty
What is a dental water jet?
These jets are also known as oral irrigators or water picks. You use them at home to get rid of plaque and leftover food from your teeth and gums. It works by streaming water at a high pressure.
Jan 10, 2013 | Health & Beauty
Hot tub is leaking
How severe is the leak?
Is the water level dropping when the tub is not in use? If so you will need inspect the back (inside the tub) portion of each jet. There is a gasket and nut on the backside of each jet body, these may come loose for crack.
If your leak is only when you have the pump running, your leak could be on the suction or discharge side of the pump. Only leaking when there is water pressure.
A temporary fix is Fix-A-Leak - a water treatment that will temporarily repair any crack up to 1/8". Its no guarantee but might help.
Sep 27, 2012 | Pool & Spa
My spa has developed a leak,water is pooling up under the spa on the tiled deck it is sitting on.Cannot locate the leak ,is it likely to be one of the hoses,or more complicated than this?
Finding a leak can be a nightmare.
If your spa has not be subjected to a hard freeze, we have had fairly good luck with Fix-A-Leak for small cracks up to 1/8"
If that does not help, start by checking all the connections at the ends of each hose for your jets & manifolds. A barb or clamp could be loose.
Also check the seals/gaskets of your suction fittings and jet bodies.
To try and determine the level of the leak play with the water level see if it still leaks when the tub is 1/2 or 1/3 full?
If your spa has a lot of spray foam insulation the task is much more difficult, good luck!
Jan 08, 2012 | Pool & Spa
This dental rinse product is not shooting water out the jet.
The problem is solved - the appliance started to work (water is shooting out the jet) . I didn't do anything but wait overnight. I guess it needed time to wake up after a long sleep. :-)
Jun 05, 2009 | Kitchen Appliances - Others
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag jet clean dishwasher model WU304 leaks - outlet hose leaks
If the hose has a hole in it you should replace it because it is worn out .Usually when these hoses leak you just need to tighten the clamp or reset the hose on the outlet.
Dec 31, 2008 | Dishwashers
Health & Beauty Logo
76 people viewed this question
Top Adidas Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Adidas Health and Beauty Expert? Answer questions, earn points and help others
